ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old June 24th, 2009, 12:34 PM   #1 (permalink)
Flye
Engine Harness connector at firewall 67-442
67 442
Replacing Engine Harness.
Looks like I'll have to remove booster to get to it, but:
Is there any 'trick' to getting the connector out of frame/connection on firewall (without breaking the connection hold pieces)?
It appears to have two plastic 'hook/slip' connectors coming out of firewall (fusebox?), that the harness connector fits over. That won't be a problem.
The problem seems to be how to unhook the existing connector without destroying it.
Thanks for help.
dan
Flye is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old June 24th, 2009, 02:44 PM   #2 (permalink)
jensenracing77
jensenracing77's Avatar
should be a bolt right in the middle. if you take out the bolt the harness should just pull off the firewall. after it is off the fire wall the two sections should just slide apart. sounds easy but sometime they can be stuck and sometime i have seen undercoat all over it to make it harder.
__________________
70 Rallye 350
72 Cutlass
00 Silhouette
90 Toronado Trofeo
jensenracing77 is offline   Reply With Quote
Old June 24th, 2009, 04:05 PM   #3 (permalink)
joe_padavano
Super Moderator
Quote:
What he said.
There may also be sealer sticking the two halves together. Keep working at it and it will come loose.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old June 24th, 2009, 04:27 PM   #4 (permalink)
svnt442
If it's anything like my 70, just unbolt it from the firewall. Then you can un-clip the two halves.
Also it was tight, but I managed to replace it without removing the booster. I had to be a bit of a contortionist, but I did it.
__________________
Randy
1970 442
svnt442 is offline   Reply With Quote
Old June 25th, 2009, 03:27 AM   #5 (permalink)
Yellowstatue
Certified Fanatic
Yellowstatue's Avatar
Smile Submerge
It may seem the wrong direction but I would take the wheel house out first, especially if you have a southern car!! Pull the wheel, remove wheelhouse and stick your face right in the plug
__________________
'57 S88 HC et al; '68 442 M20; '68 442 M21; '68 W30; '68 Vista et al; '80 -'84 Regency et al; '96,'98.'99 Aurora..Ignition ON
Yellowstatue is offline   Reply With Quote
Old June 25th, 2009, 02:46 PM   #6 (permalink)
Flye
Thanks for all. I got it off. got it back on, and now have wires to figure out what they were supposed to have been.
the added benefit, is when I pulled the master cylinder to get the booster off, I found it has been leaking, so there are opportunities at every turn....
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
'70 442 Wiring Harness Installation mugzilla Electrical 5 October 22nd, 2008 01:06 AM
68 442 Dash Harness Compatibility Jolly Green Electrical 5 September 22nd, 2008 10:07 PM
Engine Harness - Which One ? Maverick Electrical 6 July 30th, 2008 08:51 PM
72 engine harness Chumley Electrical 5 November 15th, 2007 09:16 PM
Wiring harness Removal Engine Bay?? elmo Electrical 3 September 23rd, 2007 03:49 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
