ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old June 2nd, 2009, 12:35 PM   #1 (permalink)
FATRATMATT
FATRATMATT's Avatar
What is this wire for?
I found this wire tucked behind my fuse box today and I don't know what it connects to . Any clues?? It's brown with a
white stripe. (sorry its so small I'm trying to learn how to down size)
__________________
IT'S A DELMONT NOT A DELTA!
FATRATMATT is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old June 2nd, 2009, 12:51 PM   #2 (permalink)
FATRATMATT
FATRATMATT's Avatar
A little better? I think.
__________________
Old June 2nd, 2009, 12:59 PM   #3 (permalink)
jensenracing77
jensenracing77's Avatar
i am not sure but is it the wire that goes to the emergency brake peddle to turn on the brake light when pushed?
__________________
70 Rallye 350
72 Cutlass
00 Silhouette
90 Toronado Trofeo
jensenracing77 is offline   Reply With Quote
Old June 2nd, 2009, 01:06 PM   #4 (permalink)
Texascarnut
Geezer
That thing looks somewhat like the end of a fuse holder for some sort of aftermarket gadget like a CB radio. Would be unusual for a wire that short at the fuse box to be factory on any car.
Texascarnut is offline   Reply With Quote
Old June 2nd, 2009, 01:29 PM   #5 (permalink)
FATRATMATT
FATRATMATT's Avatar
I've looked at the emergency brake pedal and can't find anywhere that this would connect, BUT I notice that the light on the cluster does not light up when the brake is set. The wire comes out from the back of the fuse box with many other wires. I pulled back the carpet and the mystery wire looks like it runs towards the driverside of the car.
__________________
Old June 2nd, 2009, 01:31 PM   #6 (permalink)
68Tom
I believe the '68 wiring harness has a brown wire with a fuse for the Rally Pack. Not really sure why you'd have one on the Delmont, however.
__________________
1968 Olds 442 Sports Coupe
4-speed/bench seat
68Tom is offline   Reply With Quote
Old June 2nd, 2009, 01:51 PM   #7 (permalink)
FATRATMATT
FATRATMATT's Avatar
Does the Rally Pack wire harness have a white stripe on it? Is it possible the harnesses were all the same, I have found power connections for..a electric clock, a map light, and under dash courtesy lights that did not come on this car. The connector on the end of this wire looks like a stiffer wire would be plugged into it. (It has a hole in the center of hard plastic)
__________________
Old June 2nd, 2009, 01:56 PM   #8 (permalink)
Texascarnut
Geezer
Quote:
Okay, I must be dense but how could the wire be running to the driver's side if the end you are holding in the photo is connected to the fuse block? Does the end in the photo appear to be some sort of socket or connector when looking down into it?
Old June 2nd, 2009, 02:08 PM   #9 (permalink)
FATRATMATT
FATRATMATT's Avatar
The end of the wire I'm holding goes behind the fuse box at the top. The wire that runs towards the driverside comes out of the bottom of the fuse box. If you can enlarge my picture you can see it running out the bottom.
__________________
Old June 2nd, 2009, 02:44 PM   #10 (permalink)
joe_padavano
Super Moderator
The e-brake pedal should have a pin switch screwed into the top of it. It looks pretty much like a door jamb switch and is designed to make contact when the pedal is pushed. There is a single wire with a bullet connector that attaches to the pin switch. It looks like what you have in your hand.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old June 2nd, 2009, 07:09 PM   #11 (permalink)
FATRATMATT
FATRATMATT's Avatar
Could this be the point of contact. I've looked all around the brake pedal and this looks like it could be it BUT It seems that I'm missing a piece.
__________________
Old June 2nd, 2009, 07:25 PM   #12 (permalink)
Lady72nRob71
Lady72nRob71's Avatar
Yep, you are missing the switch part that mounts in that silver bracket.
Grounding that brown wire should make the brake light glow when the IGN is on (providing the bulb is still good...)
__________________
-Rob Young
1972 Cutlass Supreme Convertible (442 clone) -"Lady" (My mistress...)
http://www.flickr.com/photos/robsalbum/sets/
1986 Cutlass Supreme Coupe - "Pristine"
1978 Ford (Old Faithful) a.k.a. "the Tramp"
1997 Cadillac STS (for sale - too many cars!)
1999 Harley Davidson Sportster - "the Freedom Machine"
Lady72nRob71 is offline   Reply With Quote
Old June 2nd, 2009, 07:52 PM   #13 (permalink)
FATRATMATT
FATRATMATT's Avatar
Thanks Lady72NRob71, Joe, 68Tom, Texascarnut, Jensen Racing 77, for your help in solving this mystery. Lady72NRob71 I know the light on the dash works cause when I first got the car it was low on brake fluid (Thats the only thing I didnt check!!) and when I drove it to it's first show, The pedal went to the floor on the way home. There nothing scarier then having your pedal go to the floor and a red idiot light come on at the same time. So now I guess I have a new piece to hunt down, It should be fairly easy to find this one. The last part of my vacation will be in Ohio and I know of a yard that has a couple of 68 98's and a 4 door Delmont. Thanks again everyone
__________________
Old June 3rd, 2009, 05:41 AM   #14 (permalink)
dingusboy
dingusboy's Avatar
I had a heck of a time finding one for my 65 Cutlass. Finally contacted these guys.
www.eastwestautoparts.com
dingusboy is offline   Reply With Quote
Old June 3rd, 2009, 08:08 AM   #15 (permalink)
joe_padavano
Super Moderator
Finding what, an ebrake switch? They are used on just about every GM car and truck with a foot pedal ebrake.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
Old June 3rd, 2009, 09:06 AM   #16 (permalink)
Lady72nRob71
Quote:
This was one of GM's widely-used interchangable parts.
__________________
-Rob Young
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
66 Delta 88 mystery wire. ijasond Electrical 8 October 6th, 2008 12:46 PM
What is this wire?... 72 cutlass Deputy442 Electrical 2 September 2nd, 2008 11:58 AM
What does this wire go to-78 Salon HAFROD Electrical 3 August 8th, 2008 10:58 PM
Wire behind the Console question/help Furr442 Cutlass 0 March 24th, 2008 06:04 AM
wire problems D Appeldorn Electrical 0 April 17th, 2007 02:55 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
