Speedometer Housing - Lights/Turn Signal
Old March 6th, 2017, 07:45 AM
jc1671's Avatar
Hi fellows - the night lights on the speedometer housing is very faint I barely see any lighting at all and 1 of my directional turn signal lights suddenly stopped working so I assumed a blown internal bulb. I checked the bulbs yesterday by placing them on the Oil housing unit and only 1 out of the 5 did not work however once I put the bulbs back in place the 1 directional signal that was working stopped working. I then spent close to 2 hours getting the lights to work and at one point I got both directional lights to work but they were faint and then suddenly died again. If the bulbs are good what could be the issue? Is this a case of one bad bulb causes all others to stop working OR could it be the bulb casing is not connecting properly to the housing? At this point I would like to get at least the directional signal working.
As always I appreciate the feedback. Thank you in advance.
jc1671 is offline
Old March 6th, 2017, 09:01 AM
Dave26's Avatar
First of all, what make, model,year......On some models it's easy to have a bad ground.Have you checked the ground strap? Where it screws in, it's easy to be screwed into plastic only and not the metal part of the housing.
Dave26 is offline
Old March 6th, 2017, 09:31 AM
jc1671's Avatar
Apologies - for some reason I always think the user name is accompanied by the vehicle info. It is a 70 Cutlass Supreme 350.
I have not checked the ground strap, to be honest not sure which one it is. See attached picture of the back of the housing sent along for extra help. Thank you.
jc1671 is offline
Old March 6th, 2017, 02:39 PM
Dave26's Avatar
When you remove the gauge cluster bezel, if memory serves me correctly there is a small ground strap that uses one of the speedometer screws.....that's the one that needs to be in contact with the metal portion of the dash....not the plastic.
Dave26 is offline
Old March 7th, 2017, 06:47 AM
jc1671's Avatar
Hi - when I removed the cluster bezel I did not see any small ground wire attached to any of the screws. What would be the color of a ground wire, is it gray? I tried tracing wires last night and found 1 lone gray wire which then connected to a red wire so it lost me there. Can I attach any wire to the screw to ground it?
Yesterday after another battle of changing bulbs and slowly adjusting the bulb housing (not sure what you call the plastic where the bulb is placed) I got signals to work, but then it stopped, then started again, then stopped. One signal was strong while the other weak, this on-off relationship has got to stop.
Also could it be that the bulb housing is bad?
Thanks for your help.
jc1671 is offline
Old March 7th, 2017, 08:56 AM
There isn't a ground "wire". There is a stamped sheet metal strap that is attached to the plastic dash. One mounting ear goes over the strap and the screw clamps them together. This is a 68 dash, but you get the idea.
joe_padavano is offline
Old March 7th, 2017, 10:51 AM
jc1671's Avatar
Thank you Joe/Dave - my is a bit different but I think I finally understand what you guys mean. The Strap is this metal piece in between the 2 guages shown on the picture, correct? So if the strap is attached to metal than I am back to square one as to why the signal/night light don't work? Thanks again.
jc1671 is offline
Old March 7th, 2017, 10:54 AM
Check continuity of that strap to ground to be sure.
Old March 9th, 2017, 08:02 AM
jc1671's Avatar
Thank you all for the help. I was able to get the directional signals working but the night light still very faint however the other guage lights are strong so not sure only the speedometer night light is week. Thanks again for all the help, as you can tell I am new to the classic car family so lot's of questions may be coming your way.
jc1671 is offline
Old March 9th, 2017, 04:13 PM
Dave26's Avatar
As for the dim speedo light......you may want to check the bulbs.....194 will be brighter than 161.
Dave26 is offline
costpenn
June 24th, 2015 10:38 PM
Mr Nick
May 27th, 2015 11:06 AM
lovnmy66
January 27th, 2013 08:46 AM
wizzy01
September 3rd, 2009 07:27 PM
cbogartjr
August 3rd, 2008 06:18 AM
Quick Reply: Speedometer Housing - Lights/Turn Signal
