Few electrical "Gremlins" Robski's 64 F-85
Guys trying to get some electrical gremlins fixed. The parking lights and rear license plate bulb housings have spring loaded contacts and they are sticking pushed in with no tension and when you put the bulb in there's not contact. I know I have power. Two things I have tried thus far, I pulled the spring tension contacts out and sprayed them with Deoxit.( 3rd time around trying ) I even put a tiny drop of solder on the contacts on the bulbs, lengthening the contact points just bit, that did not work. I do not think there are replacements for these. Thanks, for any craftily ideas.
Ahh pulling the wires from behind along with the PB blaster worked, spring tension is back! Weird: the 1157 bulbs plug into the socket fine, but I converted over to LED's and the cheap LED bulbs I bought will not turn when putting into socket.Those tiny little side pins on the bulb must be off a just hair. I'm contributing that too the cheap LED's I bought, like a bag of them for $10.00. Going to look around for some more. Thanks everyone for your help.
The new LED's came and they fit right in the socket. Very bright!t about finished all the wiring under the dash. have to run the wires from the front speaker the Kenwood in the gloves box. The AMP mounted in the trunk is all wired and ran the cables to the Kenwood. I have to read up on how to break in the rear speakers, there's actually a method to the madness! When everything I need to do under the dash is over with, then I will weld the seat braces in.
Eric still having issues with the license plate light. Test light shows power to it. Bulb goes in with no issues and does not light. I believe these ground to themselves to the frame or socket if you will. Only one wire to the socket.
costpenn
December 13th, 2012 10:05 AM
