Alternator Upgrade Part Number Request
I would like to upgrade my 69 442 year internally regulated open face alternator to a higher output one. I've read through the alternator upgrade sticky but gathered a 1990 Delta alternator was suggested. When I try to find one on EBay or Rockauto, I get a picture of a 3 point universal alternator with a ribbed pulley.
Does anyone have a part number I can use to order a higher amperage (65-100 amps)?
Thanks, Randy
Thanks, Randy
Thanks, Randy
Thanks, Randy
I used this one several times off a 91 corvette 105 Amp. I swap the the pulley from the serpentine to the v groove. Works great
http://www.ebay.com/itm/ACDelco-PT21...xYroVB&vxp=mtr
I was tied up when I responded and forgot to add this pigtail adapter will make it an easy swap.
Thanks, Randy
Thanks, Randy
I'm not sure what additional equipment you have that requires a higher output, but personally I'd keep the open face front housing, and swap it onto a higher output 12SI for appearance sake.
