66 Cutlass Vert 4 speed back up light schematic
After reviewing the wiring schematic in my 66 service manual and several others I still have no clear picture of what is required in the wiring routing and a schematic of just the B/U light wiring. Can anyone help?
Wayne
Wayne
On an automatic it runs from the neutral safety switch through the body harness under the carpet to the trunk. I looked on a 67 Chevelle schematic and it shows a switch at the trans, then it goes through the firewall bulkhead connector, and then to the body harness into the trunk.
ez wire schematic link:
https://s3.amazonaws.com/ClubExpress...WKvBeq3%2F0%3D
The link works for me but try this and click on technical articles and then 67-69. I'm assuming the 66 is the same.
http://www.peachstatechevelles.com/c...club_id=549354
The standard floor shift layout is in the PIM/assembly manual. It's in the electrical section I believe.
Mike, I found it. I need to get the parts and lay it out and I am sure it will make more sense. Step two will be to drop the rear bumper and install the harness from the bumper to the trunk. Need also the rear bumper filler sets. Next the switch install and the harness extension kits need to be ordered. Thanks for the help for now.
Wayne
Wayne
Wayne
Wayne
Mike
Wayne
HitTheHole
August 3rd, 2013 09:38 PM
halfmoontrail
March 17th, 2013 10:28 AM
cuttysupreme72
August 15th, 2012 04:50 AM
