| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
94 Cutlass Ciera inline fuse Where?
I have a 94 Cutlas Ciera. The A/C and the two cooling fans don't work. The power line to all three relays is dead and I cant find the 10 amp inline fuse that is supposed to feed them. Must be somewhere. Has anyone had occassion to come accross it?
Greg |
#2 (permalink) |
Senior Member
Greg check tye fuseable links at the starter pull on allthe wires .If they strech cut it out & replace it same guage & length
#3 (permalink) |
Junior Member
It is the supply line to activate the coil in the relay that is dead. Terminal 85. The schematic shows an in line 10 amp fuse. Should be live in start and run. I called the local GM dealers and they don't know where it is. For now I tied in to one of the starter wires and fused it to the pull in windings of the relay. The computer regulates the ground side of the coils so it should be ok for now. Thankyou for your reply
Greg |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cutlass Body Teardown on my 92 | mrwilde | Cutlass | 14 | 05-22-2007 01:04 PM |
| LINK to Carsurvey.org Interesting place. | jaco | Ninety-Eight | 3 | 04-22-2007 07:06 PM |
| steering wheel repair | coppertopgmc | Interior/Upholstery | 2 | 02-13-2007 04:34 PM |
| 72 Cutlass Windshield Leaks. | Eightupman | Chassis/Body/Frame | 9 | 12-10-2006 01:26 PM |
| 74 Hurst Olds numbers match, cheap | Deepsouthauto | Cars For Sale | 2 | 03-20-2006 04:14 AM |
