57 88 Fuel gauge doesn't work
Old March 12th, 2016, 05:26 PM
Mrwee's Avatar
Hi, I have a 57 88 and have installed a new fuel tank and sender and can't get the gas gauge to work, there is power to the circuit board and the holms tell me the sender is working, I was told the gauge was bad so I bought another and it didn't work either.
any ideas?
Thank you.
Mrwee is offline
Old March 12th, 2016, 07:06 PM
What happens with the gauge needle when you disconnect the wire at the sender and turn the ignition key on? Does it go to or past the full mark? If you ground the same wire the gauge should go to empty with the key on.
oldcutlass is online now
Old March 12th, 2016, 08:53 PM
Tedd Thompson's Avatar
X2 check for a bad ground. If a 57 is like a 55 the ground is the gas line. If there has been a repair done to the gas line and a rubber hose was used as a splice the ground has been interrupted ...... Tedd
Tedd Thompson is offline
Old March 13th, 2016, 08:48 AM
Mrwee's Avatar
Ground
Thank you!
I think Tedd may have something here, an early 70s 455 was installed before it bought the car, it has an electric fuel pump with mostly rubber lines from the engine compartment to the carburetor. If the old metal line was the ground where would it connect to the circuit board? do you think I could run a ground wire from the sender to a post on one side of the gauge?
Thank you,
Brett
Mrwee is offline
Old March 13th, 2016, 09:07 AM
Not familiar with yours, is there a separate ground lug on the sender? If so, you can run a ground from there to the chassis. Did you perform the test above, as it will isolate your issue to the sender or the gauge and wiring?
Old March 13th, 2016, 09:55 AM
Mrwee's Avatar
Ground
Eric,
I did run a separate ground when I put the new gas tank in and ran it to the license plat mount, I just disconnected it and ran it to the bumper mount for a better ground and it didn't change anything. I haven't done the test you suggested YET partly because the same issue was here before I changed the tank. that's why I am thinking it might be what Tedd said about the fuel line being the ground. Do you think I could run a wire from my extra ground to one side of the gauge? if so what do you think would happen?
thank you,
Brett
Mrwee is offline
Old March 13th, 2016, 10:24 AM
Proud Viet Nam Veteran
redoldsman's Avatar
It sounds like you probably have the tank grounded. Take an ohmmeter and check the tank to the frame to be sure. The possibility could be a problem with the wire from the sender to the gauge. It could be broken and open or it could be shorted to ground. I see no reason to run a ground wire from your sending unit to the gauge. These old gas gauges are pretty simple but can be a pain to get to work right. The one in my 54 has a mind of it's own.
redoldsman is offline
Old March 13th, 2016, 02:25 PM
Mrwee's Avatar
I tested from the tank to ground and got no reading so I think it's good. and then I found a bad connection in the trunk from the sender, I fixed it and tested the ohms there and got 1180, then tested at the back of the instrument panel, I put my + lead on the stud from the gauge and the - to ground and got 1390 (the tank is full) but still had no reading on the gauge. UGH.
Mrwee is offline
Old March 13th, 2016, 04:23 PM
Again, perform the test that I suggested, it will make sure all the wiring and the gauge is good, or not. If we can eliminate everything forward of the tank, the rest is easy.
Old March 13th, 2016, 06:32 PM
Mrwee's Avatar
OK, I will as soon as I can Eric, Looks like the best way at this point.
Thank you,
Brett
Mrwee is offline
Old March 11th, 2017, 09:50 AM
Mrwee's Avatar
57 Fuel gauge not working
Hi,
I have a 57 2dr post 88, and have installed a new fuel tank and sender, the wire under the dash shows the sender is working, but the gauges doesn't work when I hook it up. Someone told me they had a voltage reducer back in the day, so the gauge didn't bounce due to the fluctuation in voltage?
Any thoughts?
Thank you,
Brett
Mrwee is offline
Old March 11th, 2017, 11:05 PM
Ozzie's Avatar
Originally Posted by Mrwee
Hi,
Any thoughts?
Thank you,
Brett
It's true that some manufacturers utilized a voltage "reducer" to operate some of their gauges on, to insure better accuracy as system voltage varied (I have an AMC and Ford that are this way), however I cannot find evidence of such on the '57 Olds. The '56 Olds Shop Manual says "The gauge is compensated for temperature variation and is not affected by variation in voltage of the battery". Similarly the '57 shop manual shows no indication of a voltage controlling device either in the wiring diagram or the text. The fuel gauge appears to be fed via an SFE 9 amp fuse in the panel. In the '57 shop manual on pages 13-26 and 13-27 there is a fuel gauge testing procedure shown utilizing Borroughs testing device BT-100.
Last edited by Ozzie; March 11th, 2017 at 11:09 PM. Reason: Grammar correction & added information
Ozzie is offline
Old March 12th, 2017, 05:40 AM
I merged your new thread with the old one for the history of what you have done. Have you tried grounding the wire that runs from the gauge to the sender with the ignition key on to see if the gauge goes to "E"? Removing the wire so it is not connected to anything will drive the gauge needle to/past "F". Doing this will isolate your problem, because the wiring from the tank to the gauge, and the function of the gauge is fine, the issue is at the sending unit.
Old March 15th, 2017, 07:06 PM
Mrwee's Avatar
Fuel Gauge
Thanks for merging my threads! I tried your test and when I removed the sender wire it stayed on E, when I grounded the sender wire it barely moved off the E.
Mrwee is offline
Old March 16th, 2017, 05:39 AM
Do you have voltage at the gauge? Remove the sender wire from the gauge the needle should go to past F, ground the post where the sender wire connected and it should go to E.
If you have voltage and the above tests fail, the gauge is bad.
Old March 16th, 2017, 07:23 AM
Ozzie's Avatar
Defective gauge?????????
Ozzie is offline
GOldman
January 9th, 2013 04:21 PM
sammicurr86
February 25th, 2012 01:20 PM
Olds64
December 12th, 2009 02:49 PM
seabeepirate
Drivetrain/Differentials
August 28th, 2009 08:19 PM
rcorrigan5
June 24th, 2009 03:15 AM
Quick Reply: 57 88 Fuel gauge doesn't work
