1968 oldmobile Delmont 88 convertible.. couple of questions..
Old May 15th, 2013, 11:38 PM
DigitalFubar's Avatar
Talking 1968 oldmobile Delmont 88 convertible.. couple of questions..
Hello every! Just got my very first Olds classic.. and im very happy with it..
But i got a few question..
1. the convertible top works but when your raising it it stops after about 20-30 seconds..mid way up when you trying to close it,, you let it sit for 10-20 seconds and it works again.. tops brand new with a rebuilt pump..
the kid i got it from said that the resistor on the pump heats up and thats why it does it..
what resistor? how do i replace it? kid said it was on the pump.. for the top its self..
and 2.. car came with a street dominator intake and a eldle broc carb..
my question is this..
when i floor it in park it revs right up and is stupid loud..
but when driving it doesn't seem to get that same peppy response as in park and just revving it up.. doesn't seem like the carb is really getting that secondary ooomf when you floor it..
any ideas would be awesome.. thanks.
DigitalFubar is offline
Old May 16th, 2013, 02:54 AM
For the top, check the circuit breaker.
I believe it's on the engine side of the firewall, in the vicinity of the brake booster.
Welcome to Classic Olds.
MDchanic is offline
Old May 16th, 2013, 07:25 AM
68Delta88's Avatar
That intake is designed for an rpm range that the car can't handle.
They were never meant for low end power, and because that car is so heavy, and that you'll never find lower than a 3.08:1 axle ratio, it will struggle off the line every time. I tried the very same thing with my car, I was happier with a performer, or even the stock intake it had before.
Normally a guy would use an intake like that with deep gears, and a big stall converter.
68Delta88 is offline
Old May 16th, 2013, 04:12 PM
well according to the receipts that were in the car.. (ill take scans later so you can see for your self) it gots hi performance cams/valves/rockers/lifters/ slight bore i think...lol
and a bunch of other stuff done to the engine..
Old May 16th, 2013, 06:27 PM
Lt. Buzzkill (ret.)
copper128's Avatar
Is this a 350 or 455?
It makes a big difference. As 68Delta88 mentioned, the Street Dominator is a single-plane design which maximizes top-end power at the expense of low-end torque. Now a 455 can afford to give up a little low RPM grunt without feeling anemic, but the 350 is another story. A single plane intake and high-performance cam will kill the throttle response of a 350 in a big heavy car with automatic trans and the (350) Delmont's standard 2.78:1 rear gearing.
If you have a 350, you'd be better off with a factory intake and a Quadrajet.
If you have a 455, the Street Dominator intake can work OK if the rest of the combo is well-matched, but you'd still be better off with the Edelbrock Performer.
copper128 is offline
Old May 16th, 2013, 06:31 PM
68Delta88's Avatar
Originally Posted by copper128
is this a 350 or 455?
It makes a big difference. As 68delta88 mentioned, the street dominator is a single-plane design which maximizes top-end power at the expense of low-end torque. Now a 455 can afford to give up a little low rpm grunt without feeling anemic, but the 350 is another story. A single plane intake and high-performance cam will kill the throttle response of a 350 in a big heavy car with automatic trans and the (350) delmont's standard 2.78:1 rear gearing.
If you have a 350, you'd be better off with a factory intake and a quadrajet.
If you have a 455, the street dominator intake can work ok if the rest of the combo is well-matched, but you'd still be better off with the edelbrock performer.
x2
Old May 19th, 2013, 12:08 AM
yea sorry guys.. half the time Ive been posting ive been tired..
ok its a Delmont 88 with a 455..
any chances you could link the correct edelbrock performer for me.. so i dont go buying some thing blindly..
off the line it just grabs and goes.. good 0-60 or so i think..lol
well thanks for all the input guys..
Old May 19th, 2013, 12:31 PM
Before buying another intake tell us specifically what was done to your engine.
Olds64 is offline
Old May 19th, 2013, 11:28 PM
tomorrow ill take those scans of the reciepts of what was done to the engine..
but in the mean time here are some pictures of it..
or 1 question.. i have seen another delmont on the internet that when the top was down
there was a cover of sorts , that covered the convertible top when it is down? goes on the snaps? what is it called and where can I get one?
and here are the pics.. and a few extra just because..
and every thing is the way i got it minus the red air filter..
Old May 20th, 2013, 02:58 AM
I like the way the fan shroud is grounded.
And it's always good to have TWO car alarms, in case one doesn't go off for no reason in the middle of the night.
With all that "attention to detail," it's interesting that the PO left the voltage regulator in place when he converted to an internally regulated alternator.
By the way, I'd solder those crimped connections to the alternator if I were you.
MDchanic is offline
Old May 20th, 2013, 11:43 AM
Lt. Buzzkill (ret.)
copper128's Avatar
That's a convertible top "boot cover" or just boot. The car came with it originally.
Replacements are available from many convertible top suppliers such as these:
http://www.ezsofttops.com/p-966-1965...-24-snaps.aspx
http://www.topsonline.com/model/Conv..._Starfire.html
Disclaimer: I have no knowledge of, or experience with these suppliers, they were found with a Google search.
Old May 20th, 2013, 02:03 PM
haha yea.. it doesnt have 2 alarms.. it has an after market horn and a viper alarm..
Old May 20th, 2013, 03:26 PM
thank you for the info..
mcgink
August 28th, 2014 04:54 AM
Tvan
April 10th, 2012 02:06 PM
emorel67
August 31st, 2010 09:40 AM
theoldsmobilekid
June 26th, 2008 06:06 PM
Rallye469
March 24th, 2008 09:29 AM
Quick Reply: 1968 oldmobile Delmont 88 convertible.. couple of questions..
