Go Back   ClassicOldsmobile.com > Vehicle Lineup > Eighty-Eight
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 05-07-2007, 06:48 PM   #1 (permalink)
psmopar
Junior Member
67 delta 2 door 425 headers C code heads??
Does or has anyone tried installing 68-72 455 headers on 67 delta 88 2 door?
It has factory 425 C code head engine. Also does anyone know how to tell without taking heads off if it's big or small valve C heads?
Thanks..Paul
psmopar is offline   Reply With Quote
Sponsored Links
To remove this ad, register today!
Old 05-07-2007, 06:55 PM   #2 (permalink)
Oldsmaniac
Senior Member
Oldsmaniac's Avatar
The original 425 in your Delta would have C heads but small valve C's....only the Toro and 442 had the big valves.....The passenger side header will most likely work but the driver's side will not due to location of steering box on the frame. You would need to re-work this side and how much I do not know. The correct cast manifold is being reproduced if ya want factory style dual exhaust on the car.
Oldsmaniac is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
