Wheels, bolt pattern
Old May 27th, 2010, 04:08 AM
Palatin's Avatar
Hi, is it correct that bolt pattern on the 1960 88 is 5 x 5? Just want to go for sure.
Thank you, Uwe
Palatin is offline
Old May 27th, 2010, 06:23 AM
66400's Avatar
Yes it is.
Henry
66400 is offline
Old May 28th, 2010, 09:10 AM
Green Horn
mauls's Avatar
Instead of starting a new thread.
What is the bolt pattern for a 1965 jetstar 88? Still 5 x 5 or did they change it
mauls is offline
Old May 28th, 2010, 07:06 PM
Oldsdruid
rocketraider's Avatar
Jetstar 88 uses 4-3/4 x 5 bolt pattern. Shares it and brakes with Cutlass/Chevrolet.
The J88 confuses even longtime and hardcore Oldsmobile people. What it was, was a big Olds for someone who did not want the big Oldsmobile engine.
I'll admit to looking down my nose at the J88 for a long time, but once I accepted what it was and why it was made, I've come to like them.
rocketraider is offline
Old June 24th, 2010, 08:58 AM
Biothree's Avatar
What is the bolt pattern on a 1963 88?
Biothree is offline
Old June 25th, 2010, 04:36 PM
Summerof84's Avatar
5 x 5
Summerof84 is offline
Old June 27th, 2010, 06:45 AM
Biothree's Avatar
Originally Posted by Summerof84
5 x 5
I just realized that I made a typo. I meant 53 not 63. I just bought a 1953 Super 88 Holiday but it has no wheels. So I am going to take some tires and wheels with me to go get it. Loading will be much easier.
Biothree is offline
Old June 27th, 2010, 10:14 AM
D Appeldorn's Avatar
And a 69' 88 delta
D Appeldorn is offline
Old June 28th, 2010, 06:09 AM
Olds used 5x5 for the B and C body all the way until 76.
Olds64 is online now
Old June 28th, 2010, 07:13 AM
Yeah, well, not counting the Jetstar 88s. Just to be clear, the 5 x 5" bolt circle was used through the 1976 model year. Starting with the downsized 1977 cars, both the 5 x 4.75" and the 5 x 5" bolt circles were used. Ninety Eights, wagons, 403 cars, and HD brakes all got the larger bolt pattern. Lesser 88s got the small one. Interesting that the 1977 Indy Pace Cars used the small pattern, since they used the SS III wheels, but had 403s. I suspect that they used the larger rotors but had the studs redrilled. I'd be interested if anyone knew for sure.
joe_padavano is online now
Old June 28th, 2010, 09:17 AM
I actually didn't know about the Jetstar 88s.
I know there aren't many aftermarket wheels that fit the B and C body 5x5" wheel. I think Cragar makes a Soft 8, an SS, a Keystone Classic, and a Smoothie in 5x5". The thing about the C bodies is fitting the wheel behind the wheels skirts.
Old June 28th, 2010, 09:33 AM
it's or 5" from bolt to bolt is it?
Old June 28th, 2010, 11:00 AM
Nooooooo! The measurement of a bolt CIRCLE is the diameter of a circle that passes through the center of all the wheel studs. If the pattern has an even number of studs, then yes, you can simply measure the center-to-center distance of two opposite studs, which is the diameter of the circle. A five bolt pattern does not have two opposite studs. Through a happy coincidence of geometry, on a five-bolt pattern you can measure from the center of one stud to the outside edge of the third stud and come close, but this measurement can vary based on the stud diameter, so at best it's an estimate.
You might want to look again. The 5 x 5" circle is shared with LOTS of popular cars and trucks, including the 1990s Impala SS and many half ton GMC and Chevy pickups. There are thousands of aftermarket wheels available with that pattern. Fitting behind the skirts is simply a function of picking the correct width and offset. Some wheel vendors offer a wide selection, some don't.
Old June 28th, 2010, 11:32 AM
ok did'nt knew that, had yet alway's 5 bolt patern on my car's
Old June 28th, 2010, 11:39 AM
Biothree's Avatar
Right now I am going to get some junk wheels and tires just to get it loaded and home.
Biothree is offline
Old June 28th, 2010, 11:47 AM
All I know, is there are only 3 or 4 wheels Cragar makes that have 0 offset, 4 inch backspacing, in 15" x 7" size. I don't know about other sizes (ie. 16 or 17 inch).
Old June 29th, 2010, 12:37 PM
65 Dynamic 88's Avatar
So then a 1965 Dynamic 88 has 5x4.75 also, correct?
65 Dynamic 88 is offline
Old June 29th, 2010, 01:13 PM
No. Again, JETSTAR 88 used the 4.75" circle and associated smaller brakes. All other full size cars - including Dynamic and Delta 88 - used the 5" circle.
Old July 14th, 2010, 09:59 AM
Biothree's Avatar
Thank you, Uwe
They were 5X5. Number one lug center measures approximately 4 7/8 to the third lug center.
Biothree is offline
Old July 14th, 2010, 10:02 AM
Biothree's Avatar
Thank you, Uwe
Biothree is offline
Old September 6th, 2010, 03:14 PM
Theo's '67's Avatar
I have two questions:
What volt pattern is a 67 delta 88 vert and What body typ is it...B,C, ETC?
Theo's '67 is offline
Old September 6th, 2010, 03:42 PM
The VOLT pattern is 12...
The BOLT pattern, however, is still 5x5
https://classicoldsmobile.com/forums...platforms.html
Old September 6th, 2010, 03:48 PM
nickd's Avatar
What is the 65 Jetstar 1 bolt pattern? I believe right now it has old buick Lasabre wheels on it right now.
nickd is offline
Old September 6th, 2010, 04:39 PM
One more time...
ALL full size Oldsmobiles from 1959 through 1976 used the 5 x 5" bolt circle on the wheels EXCEPT the 1964-66 Jetstar 88. Do not confuse the Jetstar 88 with the Jetstar I, which did use the 5 x 5 pattern. ONLY the Jetstar 88 used the smaller pattern (5 x 4.75")
Old September 7th, 2010, 05:52 PM
Theo's '67's Avatar
thank for the help and correction
Old November 21st, 2010, 12:57 PM
OLDZGUY's Avatar
Check out www.carnut.com/specs/specs.html for all this info and more...
I have a '63 Olds 88 2dr HT with Centerlines from Summit Racing and Goodrich TA's.
OLDZGUY is offline
Old November 21st, 2010, 08:49 PM
russell7088's Avatar
any reputable wheel store will help you with wheels there are many out there, i used to work at discount tire for six years and the choice was hard for me but the amount of wheels that will fit behind your skirts is numerous centerline will build a wheel for your offset as will many billet manufacturers if it is steel wheels you want then most should fit behind the skirt
russell7088 is offline
Old November 22nd, 2010, 06:30 AM
That Delta looks AWSOME! I haven't bought wheels for my 71 98 yet, but I plan to this spring. I might have to check out a local wheel and tire shop for "expert help."
Old February 15th, 2017, 02:08 PM
1965Delta88's Avatar
I am looking for wheels similar to the Oldsmobile Rallye SS1 but with the 5x5 bolt pattern. Does anybody have an idea?
1965Delta88 is offline
Old February 15th, 2017, 02:20 PM
I'm not aware of anyone (factory or aftermarket) who makes a version of that Magnum 500 wheel in a 5x5" bolt pattern. They only came in 5x4.5" and 5x4.75". The only thing at all close is the Buick sport wheel, which was offered in 4.75" and 5" patterns. People often confuse these with SSI or Magnum 500 style wheels, but the spokes are shaped differently.
Old February 19th, 2017, 08:14 AM
  #31
Thanks for the fast reply!!
I think these are actually on the car right now, but in pretty poor condition. Do you know if the oldsmobile patch that goes in the middle of the SS rims will fit on the buick wheels too?
Anybody got suggestions for a black 65´Delta 88 that are classic but look a little more sporty and are maybe available for wider tires than stock?
Thanks in advance
Old February 19th, 2017, 08:17 AM
  #32
Thanks in advance
No idea on the wheel center. I got Torque Thrust Orignals (VN309s) for my 67 D88.
Old February 19th, 2017, 11:20 AM
  #33
Originally Posted by barron1941
As for the 77 pace car I beleve some chevrolet wagons used the larger brakes with 5x4.75 pattern.They might have used them.
All the 1977-1990 cars with HD brakes, including the Chevy wagons, used the 5x5 bolt pattern. The 1977 pace cars used one-off SSIII wheels with the 5x5 bolt pattern. Only a handful were made. According to member Rocketraider, there was a set for sale at Homecoming a few years ago.
russell7088
March 8th, 2018 08:22 AM
dads72
October 3rd, 2014 04:48 PM
ss427
January 13th, 2008 08:57 AM
J-(Chicago)
November 28th, 2007 04:00 PM
2 door cut
May 20th, 2007 11:34 AM
Quick Reply: Wheels, bolt pattern
