PS for '58 Super 88
Old October 4th, 2016, 01:02 PM
holidaysedan's Avatar
PS for '58 Super 88
Like to add PS to my '58 manual steering Super 88 (what on earth were they thinking - it has power brakes though!!), and do have access to a '57 98 parts car that is complete... it has has essentially the same 371 4 bbl engine, trans and chassis. What parts would I need to scavenge from it for my car, besides the pump, hoses, and slave unit on the lower column. Do I need the whole column? Pulleys? Other parts?
Thnx in advance for assistance.
Roger in central upstate NY
holidaysedan is offline
Old October 5th, 2016, 10:09 AM
D. Yaros's Avatar
Well, you would certainly need a pulley on the engine that accepts the PS drive belt.
D. Yaros is offline
Old October 5th, 2016, 07:04 PM
Phantom Phixer
Charlie Jones's Avatar
You will certainly need the complete column.
You will also need to change most of the steering linkage .
Pitman arm , idler arm , steering arms , to name a few .
Charlie Jones is offline
Old October 6th, 2016, 06:33 PM
Yellowstatue's Avatar
Are you calling the steering box, the slave unit? Just take everything you see that the drive belt touches and the hoses attach to.
Yellowstatue is offline
Old October 6th, 2016, 07:47 PM
chequenman's Avatar
What you're saying is he doesn't need the steering column... Huh
chequenman is offline
Old October 8th, 2016, 11:41 AM
Phantom Phixer
The manual steering has a one piece steering column with steering box.
The power steering has a separate column and steering box separated by a "rag" joint.
Old October 9th, 2016, 01:59 PM
Believe that the manual steering column is one piece is correct, I just can't find the part #s in the '51 to '59 factory parts book to confirm it.
I've got the PS pump, steering box, joint, plus the relay rod and its attached arms off of the '57 parts car so far.
valmaye
February 19th, 2012 10:41 AM
aholiday
January 11th, 2010 05:57 AM
<RUREDDY2GETSUM>
February 17th, 2005 03:16 AM
eckertauction
July 25th, 2004 03:44 PM
Paula
August 10th, 2003 10:22 PM
Quick Reply: PS for '58 Super 88
