Go Back   ClassicOldsmobile.com > Repair & Restoration > Transmission and Driveline > Drivetrain/Differentials
Sign in using an external account
Register Forgot Password?
Search
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
submit to reddit
LinkBack Thread Tools Search this Thread Display Modes
Old August 27th, 2008, 11:52 AM   #1 (permalink)
Just A BaBy {:
easytobedead's Avatar
1987 cutlass rear end!
ok i was told for people that have limited slip rear end, that if you want bigger gear ratio an keep limited slip that you can get it out of a olds station wagon? true? or false?
__________________
+2001 Aurora
+2003 4.0 Aurora
+1979 hurst/olds
+1997 Jeep cherokee 5.5" lift 33 MTZ
easytobedead is offline   Reply With Quote
Old August 28th, 2008, 05:18 AM   #2 (permalink)
Lady72nRob71's Avatar
Maybe...
A Cutlass Cruiser of the same vintage ~may~ be a good source for lower gear ratio as the wagons often came equipped to tow trailers and move lots of weight (cargo, people, etc). As for limited slip, it was an option and it may or may not be available.
A B-body wagon axle (Custom Cruiser) would be far from a bolt-in.
How low a ratio do you wish to go?
I believe the wagons will have the 7.5" housing as all the other standard G bodies.
If you want a very low ratio that requires an 8.5" housing, those would only be available from a 442, MCSS, or Regal GN (to be bolt-in).
Hope this helps...
__________________
-Rob Young
1972 Cutlass Supreme Convertible- (442 clone) -"Lady" (My mistress...)
http://www.flickr.com/photos/robsalbum/sets/
Lady's interior makeover Rally Pac stuff
Front end job Underhood resto
1986 Cutlass Supreme Coupe - "Pristine"
1978 Furd Pinto (Old Faithful) a.k.a. "the Tramp" - in the family since new.
1997 Cadillac STS
1999 H arley-Davidson Sportster - "the Freedom Machine"
Lady72nRob71 is offline   Reply With Quote
Old August 28th, 2008, 05:50 AM   #3 (permalink)
Unless your 87 is a VIN 9 442, you have the weak-kneed 7.5" axle. Look under S-10 pickups for steeper gear sets. The S-10 axle housing is different due to the leaf springs, but the center section should swap with yours.
__________________
Joe Padavano
62 F-85 Deluxe wagon
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old August 28th, 2008, 10:08 AM   #4 (permalink)
Just A BaBy {:
thank you very much!i am just looking to up the anti a bit. not going super crazy. but don't like the gears in it right now but i don't want to rip the hole end out. Is that to much to ask>?
__________________
+2001 Aurora
+2003 4.0 Aurora
+1979 hurst/olds
Old August 29th, 2008, 08:34 PM   #5 (permalink)
gear swap
If you are going to swap out gears your better off removing the whole rear. It will be way easier for install and you can consentrate on getting it in correct. If it is your first swap you will need all the help you can get. Plus you can clean up the under carriage etc. If you have a lift then your probably ok or you young and have alot of back left. I am 40 and done with the laying under car deal...lol. Jim
I can get you gears also if you need. Here is some of the problem with 7.5 posi unit from the late 70's and early 80's. One the posi unit are usually 2 series which means 3.08 is as high as you can go with that carrier. They do sell spacers (50.00) and also thick aftermarket gears too. (which I sell also)
now you can get a s-10 posi (limited slip unit BUT it usually is a gov lock eato which are really not made for performance driving... They are to just get you out of the mud or ice or snow at lower speed when your stuck. NOT burning out or drag racing...They tend to blow up under the lock up mod which happens when they sense slipping of one wheel faster than another. THEN the unit locks up. Performance units are always on...They are usually found in the cars. NOT trucks. Hope this info helps too. Jim
monzaz is offline   Reply With Quote
Old August 29th, 2008, 10:53 PM   #6 (permalink)
Just A BaBy {:
thank you very much! how much is all this ? an i am not looking for the best but a good rear. an yea i will be working on my back with my little bro{who is in love with 80s delta 88} i need all the info i can get !!!!!!!!!!!!!!!!!!
__________________
+2001 Aurora
+2003 4.0 Aurora
+1979 hurst/olds
Old August 30th, 2008, 06:04 PM   #7 (permalink)
rear end parts and info
Please PM me and I will pass you a phone number and will go over what you want the car to do and how much you have to spend, Hopefully we can find something decent that will work for you. Jim -J D Race.com
ClassicOldsmobile
1957 Oldsmobile
Paid Advertisement
submit to reddit
Search this Thread:
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
65 Cutlass Rear End Oldsproject Drivetrain/Differentials 15 December 11th, 2010 01:17 AM
What rear end gear-87 Cutlass HAFROD Cutlass 2 March 15th, 2007 01:29 PM
1987 cutlass rear wheel drive for sale skip Cars For Sale 0 August 21st, 2006 03:10 PM
83 Cutlass Supreme rear end mods <George> Drivetrain/Differentials 1 July 12th, 2004 11:00 AM
rear end rebuild 72 cutlass crank.it Drivetrain/Differentials 2 April 30th, 2003 07:01 AM
Advertising - Privacy Policy - Terms of Use - Jobs
All content Copyright © 2008 by Internet Brands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
