Driveshaft / Propeller Shaft Removal question on '56 Olds
Old June 12th, 2014, 06:25 AM
JackJack56Olds's Avatar
Are there any tricks to removing the shaft from the companion flange at the diff? It hasn't budged with a couple taps of a deadblow. might just be rust or paint that glued together from the last time it was out. Just want to make sure before I start beating and prying.
JackJack56Olds is offline
Old June 12th, 2014, 09:21 PM
Ozzie's Avatar
Post From the 1956 Oldsmobile shop manual
I don't know of any tricks. I have a '55 and it is "straightforward".
Pages 6-2 and 6-3 of the 1956 Oldsmobile shop manual says to remove the propeller shaft:
1. Remove four rear universal joint bolts.
2. Use a piece of soft wire or a heavy rubber band to hold trunnions onto spider journals and prevent loss of bearing assemblies when joint is disconnected.
3. Mark the universal joint trunnions and companion flange and then disconnect universal joint from companion flange.
Your suspicions are probably the cause of its reluctance. Just pry and beat with care so as to not damage anything.
Ozzie is offline
Old June 14th, 2014, 08:59 AM
so I pryed it off and it was fairly easy but the other end won't slide out of the transmission. there is a small screw on the slip yoke but I don't know if that is holding it on or what. I know on my '89 mustang the d/shaft slides out easily. this one is pretty well stuck with me pulling and yanking. any idea if the screw has something to do with it?
Old June 14th, 2014, 11:28 AM
Ozzie's Avatar
The "small screw" is a plug for a lubrication port. It was intended to be removed every 5000 miles and get lubricated with a special lubricant (567196) and then get replaced. In practice, it was often ignored, and the slip yoke suffered added wear. On my '55, I took it out and replaced it with a conventional chassis grease fitting. Then it could be lubricated regularly with the other fittings using conventional chassis grease. If you choose, you can install the grease fitting and pump in some grease. If it's never been lubricated it will take a lot of grease before it appears. That may be the reason it is currently "stuck". If you get some grease in it and "wiggle and pull" it carefully it may come out. Be sure to inspect it for excess wear before re-installing it.
Ozzie is offline
Wood
34
March 28th, 2022 05:31 AM
Frogge467
March 24th, 2012 11:09 PM
chrisneu68olds
March 21st, 2012 12:40 PM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
ChrisM
Drivetrain/Differentials
August 12th, 2008 02:22 PM
Quick Reply: Driveshaft / Propeller Shaft Removal question on '56 Olds
