ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Chassis, Drivetrain, Brakes, & Related > Drivetrain/Differentials
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old December 12th, 2007, 06:13 PM   #1 (permalink)
Totumfrog
Junior Member
U-joint removal
I have a 70 olds Cutlass Supreme convt. I recently had the TH350 rebuilt and I reinstalled last weekend. I bought new u-joints to replace them while I had the drive shaft out. However, I can't get the old u-joints off. They don't appear to be the originals nor do they have the "c" clip on the inside. I have some "plastic" tips on either side of the universal housing. Someone said that they used to melt plastic into the housings to hold the u-joints and the only way to get them out is to heat them with a torch and pound them out when the plastic melts. Anyone familiar with this?
Collin Totumfrog Johnson
Totumfrog is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old December 12th, 2007, 06:20 PM   #2 (permalink)
J-(Chicago)
Seasoned beater pilot.
J-(Chicago)'s Avatar
I too have heard that.
Supposedly you heat them till they "POP" then you can remove them somehow with a special tool. Doesn't sound safe, or fun. I leave u joints up to my driveline shop, however I went to junior high school with the guy, so I don't know what they will [u]really[/U]charge .
Also there are different ones that you can re install.
I went with greaseables.
Here is a pic of the tool.
__________________
I'd rather have a numbers matching poker hand.
J-(Chicago) is offline   Reply With Quote
Old December 12th, 2007, 06:56 PM   #3 (permalink)
joe_padavano
Super Moderator
The injection molded plastic retaining ring is the factory method of retaining the ujoints, so they probably are original. You can try heat, but I've just used a pair of sockets (one slightly smaller than the U-joint cup and one with an ID slightly larger) to press them out in a big bench vise or hydraulic press.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old December 12th, 2007, 07:29 PM   #4 (permalink)
ozoneblue
ozoneblue's Avatar
Send a message via Yahoo to ozoneblue
Yes a little heat makes the job a lot easier ,I if you dont have a torch & going to buy one get MAPP gas not propane,Alot more heat quicker Caution ! just heat until plastic flows
ozoneblue is offline   Reply With Quote
Old December 13th, 2007, 12:59 AM   #5 (permalink)
dynamic88
i recently had to replace the ujoint on my 65 olds. it had the melted plastic rings also. the only way i was able to get it out was with a small socket and a press. They are extremly difficult to get out without a press.
dynamic88 is offline   Reply With Quote
Old December 13th, 2007, 04:57 PM   #6 (permalink)
Totumfrog
Junior Member
Thank you all. I think I might go to a local shop with drive shaft in hand and have them take them out. I don't have a big enough vise nor do I have a gas cylinder / torch etc. Good to know what I need to do though. Thanks again everyone!!!!
Collin Johnson
Old December 29th, 2007, 09:51 PM   #7 (permalink)
Topless72
Don't Go!
I just did mine 2 days ago and it's not rocket science.. I've done them for years the same way...
I use a torch and heat up the outer area around the plastic tip until it comes out like a snake. Do each one separately... Don't heat the boots too much or they may pop some hot grease around.
Use a 3/4 inch socket to drive the ujoint out.. the method I use is:
1) set up support on something like a wood block leaving the ujoint cap able to be driven out to air.
2) Bang out one end (making sure there is no C clip (odd not to have one?)) until the furthest cap is out. I then reverse it and use a dowel or ratchet extension to drive the shaft back thru the other way to remove the other cap. I can't remember if the cap will continue on thru to clear removal if you just kept banging after the first cap was out. Sometimes the grease fitting can get in the way, so remove it to make sure...
3) It's better to use a lubricant like anti seize to help the install (apply to cap and hole). To install a new one sit the cap where it will be driven and bring the ujoint shaft in from below. This keeps the needle bearings in place while installing. You need to remove the other end cap too . When removing, do it in a twist motion to keep the pins from binding/falling.
4) Once the first cap is installed to proper depth using the 3/4 socket, rotate and get ready to do the other side. Set the cap and again bring the shaft up to seat in the hole to keep the needle bearings from popping out.
5) When that's in, put the c clips in place.
Feel free to email if you have any questions. bradyjc@comcast.net
Topless72 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
69 fuel gauge removal 69-Sguy Cutlass 7 May 1st, 2008 09:43 AM
Dashboard Removal ? The_Jeremiah Interior/Upholstery 10 December 20th, 2007 12:31 PM
ac removal jd75 Other 8 July 4th, 2007 09:19 AM
seat removal Chumley Cutlass 0 October 31st, 2006 05:44 PM
a/c pump removal bfhcs Other 3 October 27th, 2005 01:21 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
