Go Back   ClassicOldsmobile.com > Repair & Restoration > Drivetrain/Differentials
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 11-17-2007, 10:16 PM   #1 (permalink)
theone81
Junior Member
455-th400-??????
so i got my 455 with my turbo 400, but im tryin to figure what kinda gears i need to use with it. now im maxin at like 65 miles per hour. i think im in the 4. somethings. im thinkin like 3.42 or something close anyone with this combo let me know what you got and how well its workin
theone81 is offline   Reply With Quote
Sponsored Links
Old 11-17-2007, 11:10 PM   #2 (permalink)
dar83501
Brewsmobile > Bluesmobile
That's a bit unusual... 4.10's would get you to top out at 100 to 120 miles per hour, not much more...and it would sound something like a leer jet passing 30 feet overhead crossed with a dying moose in your ears. There should be markings on your rear differential case that will indicate what gearings it has.
I wouldn't think 3.42 would make you top out at 65...that just doesn't sound right at all.
dar83501 is offline   Reply With Quote
Old 11-18-2007, 01:32 PM   #3 (permalink)
Oldsguy
Oldsguy's Avatar
What kind of car? What is the id number stamped on the passenger side axle tube?
__________________
Dan
'46 2 door
Oldsguy is offline   Reply With Quote
Old 11-18-2007, 02:50 PM   #4 (permalink)
68conv455
Member
Did you mean you typically don't drive faster than 65...and your running 4000+RPM?
Either way, if your looking to select new gears, you have a simple math problem. The TH400 has a 1:1 final drive ratio, so to find out how many rev's your engine does at some miles per hour you only need:
Tire circumference, rear gear ratio, and some unit conversions. I set up an excel spreadsheet with my ideal highway cruise speed and let it calculate engine RPM with various gear ratios before I made my choice. Then I selected gears based on my tolerance level to noise and gas mileage.
68conv455 is offline   Reply With Quote
Old 11-18-2007, 02:54 PM   #5 (permalink)
Redog
Alero Chapter Secretary
I have 3.42's with a 400th and a 68 350.
Runs great, but since I switched to HEI the car's revving 500 RPM's too high.
With the points I was doing 2600 to 2700 at 65, now I'm at 3000 at 55
Redog is offline   Reply With Quote
Old 11-18-2007, 08:28 PM   #6 (permalink)
texasred
Super Moderator
texasred's Avatar
Changing to an HEI will not change the RPM/miles per hour formula. That is purely a function of gear/tire combo (and transmission or clutch slippage, as applicable). Perhaps your tach needs calibrating?
C.J.
__________________
Home of the 1971 Cutlass Supreme convertible Super Karate Monkey Death Car.
texasred is offline   Reply With Quote
Old 11-18-2007, 08:31 PM   #7 (permalink)
texasred
Super Moderator
texasred's Avatar
Quote:
So are you saying that your car won't physically go faster than 65 miles per hour or that you are redlining your tach at 65 miles per hour?
What is your tire size and what is your rpm at 65?
C.J.
__________________
Old 12-29-2007, 08:59 PM   #8 (permalink)
Topless72
Senior Member
3:23's or 3:31's aren't bad for highway..
Topless72 is offline   Reply With Quote
Old 03-13-2008, 06:25 PM   #9 (permalink)
theone81
Junior Member
yea its "sounds" like its redlining. i don't have a tach in it just yet. but it f-ing screams at around 65. i just tore the rear apart today and it has 3.73's in it. something seems really off with this to me. a lot of people are racing there cutlass' with 4.11's and mine just seems like its ...... sucking. lol but when im doing like 30-35 the speedo is almost buried just pass 80 or 90 (can't remember what is the final number on it) someone mentioned a torque converter issue.... dunno seems like im missin something but the car goes like a bolt of lighting till 65 or so. like i said rough estimate being my speedo dosen't work and no tach.
Old 03-13-2008, 06:53 PM   #10 (permalink)
theone81
Junior Member
oh and tires are like 245 65 15
Old 04-03-2008, 02:45 PM   #11 (permalink)
gearheads78
Member
There is a great gear calculator on the Richmond gears website. You can play with it to figure exatly where to want to be for your combo.
__________________
66 Cutlass Restomod/Protouring
gearheads78 is offline   Reply With Quote
Old 05-14-2008, 03:58 PM   #12 (permalink)
my67olds
Junior Member
I have a 461BB/400TH and 3:90 gear and 65mph is the most I would run on the freeway, if I stab it I could jump to over 100 then bump neutral and coast a bit. I dont use the car on the street anymore and I dont remember the tire size.
my67olds is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
TH400 wire hook up OLD SKL 69 Transmission 1 05-10-2007 04:10 PM
455 to 425 th400 swap? delta88NC Transmission 4 03-27-2007 03:53 PM
TH400 swap in 84 Cutlass grimlock Transmission 1 01-23-2007 09:24 PM
where can i find a 455 and a th400 for my cutlass cutlass68 Big Blocks 9 12-02-2006 04:18 PM
Cutlass body parts, 455/TH400 For Sale jasonscj5 Parts For Sale 3 05-30-2006 04:42 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
