| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
can any one give some advice on bushing replacement,to use poly or the stock rubber,i've been told the poly makes the ride to stiff and will turn the car into a rattle box after 10'000 miles....72 cutlass convert.....thanxxxxxxxx
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
bushings
This a old thread too but worth discussing.
poly bushings will make the car stiffer... and stock rubber will give you back your stock softer ride. poly pluses- -stiff in turns and prevents body and suspension roll. -handles torque better -pretty much lasts forever -cost is relatively cheap poly minuses- -transfer more of the shock of the road through the suspension rubber pluses- - soft factory ride - for show they look stock - keep down noise being transfered through the drive line rubber minuses - does not transfer torque as well as poly - body sway more in turns - has a much shorter life and breaks down with heat and oil etc. - cost tends to be more than poly ??? yes that is correct. at least compared to moog. I am sure there are more opinions...Jim |
#3 (permalink) |
Super Moderator
Poly on the rear control arms is a problem. The typical GM 4-link rear suspension causes the control arms to twist slightly as the suspension moves. The factory rubber bushings are soft enough that they absorb this twisting with no problem. Poly bushings are much harder and will cause the rear suspension to bind. The solution is to use the upper arms that have ball fittings at the forward end. This solves the binding problem.
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#4 (permalink) |
Landyacht Club President
I redid the suspension on my car a few years ago and I ordered rubber bushings. I am still pleased with the ride quality and lack of road noise in my car. The only thing I have to do now is restore the interior and I will be set.
| Thread Tools | |
| Display Modes | |
