ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Chassis, Drivetrain, Brakes, & Related > Drivetrain/Differentials
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old April 6th, 2007, 02:59 PM   #1 (permalink)
shaks 442 clone
Senior Member
Send a message via AIM to shaks 442 clone Send a message via MSN to shaks 442 clone
gear ration of a 1970 442?
i recently bought a 12 bolt rearend in a package deal got a gas tank rearend and front disc brake conversion kit for 400 bucks
i was wondering what was the gear ratio of a 1970 442 because i heard they were a limited slip differential and im getting ready to do my rearend i was thinking of 3.55 but i rather go with what the 442 originally had
hope someone can help me out
shaks 442 clone is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old April 12th, 2007, 08:18 AM   #2 (permalink)
70Wcars
Most common was 3.23 with some 3.42 and as stiff as 3.91 in some 4-speed cars. Remove the cover and divide ring gear teeth number by pinion teeth number to see what you got.
Hope this helps
__________________
Dan S
70 442 W-30 4-speed
70 442 W-30 Post Coupe Bracket Race car...10.66 @ 3650lbs.
70Wcars is offline   Reply With Quote
Old July 11th, 2007, 11:03 AM   #3 (permalink)
smcurro
Send a message via AIM to smcurro
An easier way to figure out the ratio is if the axle is a posi turn the axle one full rotation and count the rotation of the pinion. If the differential is open then fix one side of the axle in place and turn the other side two full rotations again counting the rotation of the pinion. If the pinion turns three and a half rotations, your gears are 3.50 to 1. This is much easier than taking things apart.
smcurro is offline   Reply With Quote
Old July 11th, 2007, 11:13 AM   #4 (permalink)
joe_padavano
Super Moderator
Quote:
Unfortunately, it can sometimes be difficult to tell the difference between 3.23 turns, 3.31 turns. and 3.42 turns. I turn the pinion until the axle shaft turns ten times. It's much easier to tell the difference between 32.3, 33.1, and 34.2, for example.
As for available ratios, it could have been anything between 2.73:1 and 5.00:1.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old July 11th, 2007, 12:52 PM   #5 (permalink)
smcurro
You're right, that is a better idea, and then divide by ten. Good thinking!
Old September 4th, 2007, 09:30 AM   #6 (permalink)
monzaz
IDing rears
Again if you are going to rebuild it you might as well crack it open ...that fluid should be changed after 30 years anyway...lol.
monzaz is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
