Replacing wheel bearings on Type O Rear
Old May 17th, 2010, 04:02 AM
Classiccarjohn's Avatar
Can anyone tell me the proceedure to change wheel bearing on a type o rear Code TO? Will the axels pull out? Do the new bearings need to be pressed on? Any info would be helpful as I never did this job before.
Classiccarjohn is offline
Old May 17th, 2010, 05:50 AM
2blu442's Avatar
This thread described the newer style 8.5 rear end, but I believe the process is the same with the type O. You may have a different style bearing, open cone shaped vs sealed roller bearing, but they're both bolt in axles and I think the wheel bearings are both pressed on and off. John
https://classicoldsmobile.com/forums...bolt-axle.html
2blu442 is offline
Old May 18th, 2010, 06:29 AM
507OLDS's Avatar
Yes,the axles unbolt from the housing,& the bearings are pressed-on. The 67-69 Cutlass/442 O-axles came with a sealed bearing,& an inboard seal,pressed into the axle tube.Those numbers are RW507CR and 8594S. The 1970 O-axle came with a roller bearing,& an outboard seal,on the outer side of the bearing. Those numbers are SET-9 and 712146.
If you have the 67-69 style,you will want to inspect the axle shaft where the bearing is pressed on.These axles were a softer material,& they have a history of the bearings spinning on them,thus turning the diameter down,& making the axle junk beacause it can no longer hold the bearing or keep it perfectly centered in the shaft.
507OLDS is offline
Old May 18th, 2010, 09:49 AM
Thanks Brian.
fv64olds98
September 10th, 2013 09:18 AM
costpenn
Drivetrain/Differentials
March 29th, 2013 07:48 AM
Aron Nance
October 4th, 2012 07:20 AM
g77rvd
April 12th, 2011 07:21 AM
oldzy
September 14th, 2010 05:40 AM
Quick Reply: Replacing wheel bearings on Type O Rear
