| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
quick change rear end
Anyone here used them? Planning on it. Easy way to have dual purpose rear,able to have rear disc cheaply. That way I can drive to the strip,change gears in 20 min and have a lot of fun,then change back and go home.What are your thoughts?
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Sounds like a Ford rear end.
#3 (permalink) |
REAR END
YEP FORD MOPAR TOYOTA ETC...LOL
Dude just buy a overdrive tranny and be done if you want the best of both worlds. This will be too expensive and way wacky to install. They can build the 700r4 and even the 200r4 to handle alot of power these days. Give a tought in that direction too. Jim |
#4 (permalink) |
A quick change rear has the final drive set up in the rear of the diff. pull a cover swap gears and your done in 20 min. NOT like a ford rear.Still can't go with overdrive,going from 2.73 to 4.88 with just 1 extra gear in trans?
#5 (permalink) |
Telecom Guru
Aren't most of the quick change diffs noisy due to the style of gears they use? If you were to buy a brand new one, ready to install in your Olds, it would probably cost about the same as a Gear Vendors overdrive. The difference being the Gear Vendors unit will change at the flick of a switch. That way you're ready for the occasional stoplight race. Not that anybody would actually do that. Because that would be illegal and unsafe.
__________________
1976 442, Value Package, 350, All original Silver w/black stripes, Black interior Purchased 9/26/09 and waiting for reconditioning. **Looking for an 8.5" Posi & 3.23 to 3.73 gears. 2001 Suburban daily urban assault vehicle. |
#6 (permalink) |
Local racer has one for 400.00 with correct size rear brake set up. I need to get longer tubes/axles and spend a few hours welding in spring perches.Some noise from rear,nowhere near as bad as a gear drive.Then I have unlimited gear ratios available. Just seeing if anyone has had the idea to use something like this. I see the major manufacturers have "street" versions of their units available.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| ?? Rear End | egknz | General Questions | 1 | April 21st, 2009 05:39 AM |
| rear end | 1978 cutlass supreme | General Discussion | 1 | August 23rd, 2008 10:32 AM |
| Need to ID rear end | Bill Foster | Drivetrain/Differentials | 4 | July 16th, 2008 09:48 PM |
| Rear end help | Redog | Drivetrain/Differentials | 6 | September 13th, 2007 09:57 AM |
| looking for a rear-end | mal1form | Cutlass | 5 | January 12th, 2007 10:25 PM |
