I broke my '63 F85.
Unless your lucky enough to find an original CV repair kit or good used driveshaft in a junk yard, You can't get the parts anymore. G.M. discontinued them in 1971 and nobody in the aftermarket makes them. How did you break the seat??? Pic doesn't show it but it is two pieces.
This might help...
I have the section with the ball I will sell, and the seal can be replaced with National Seal # 13X22X6 it's a hair thicker then stock but works nicely. That leaves the two or (sometimes three) piece section that the spring pushes against ball that you still need.
It was vibrating like hell. And it took itself apart. I don't have a picture of what it looked like before or after it broke, but it was working fine before it went to pieces on me. It was rebuilt 5 years ago by a master machinist and vintage hotroder who died a couple years after. So questions I could have as to why the repair failed (or what I have done to it) are for a dead man.
That sounds great. Do you have the seat and stop as well?
[QUOTE=RoseCityOldsmobile;997072]It was vibrating like hell. And it took itself apart. I don't have a picture of what it looked like before or after it broke, but it was working fine before it went to pieces on me. It was rebuilt 5 years ago by a master machinist and vintage hotroder who died a couple years after. So questions I could have as to why the repair failed (or what I have done to it) are for a dead man.
I had a problem with mine for a long time. I tried to make a set of those "shoes" from a Chevy rocker arm pivot ball, It would last about two weeks and would fail. I learned the only way to fix these shafts is with the correct parts. Also I would send it out for a rebalance to make sure it wouldn't vibrate or it will self destruct quickly.
RyanFink
September 4th, 2022 01:50 PM
J'ville
Drivetrain/Differentials
September 4th, 2007 09:50 AM
