What is the difference between "O" type SE & S6?
Yes I know they are different numbers/letters.
1969 O type rear with a S6 rear 3:23 is " standard type w/JL2(Power Disc Brakes)
and the SE rear 3:23 is standard type with No Power Disc Brakes.
So my question is what's the difference? Internal - External?
Mike
Mike
Keep in mind that the code refers to the entire axle assembly, not just the gears. The only thing I can imagine that is different for power disc vs. no power disc is the size of the rear wheel cylinders on the backing plates.
SE = 3.23:1 open differential with drum brakes (power or no power).
S6 = 3.23:1 open differential with the power disc brake option.
Randy C.
PS: The 3.23:1 anti-spin differential with drum brakes (power or no power) is coded SF, and the same differential with power disc brakes is coded S7.
Randy C.
L77F85
Drivetrain/Differentials
16
November 29th, 2013 06:19 AM
rcorrigan5
September 30th, 2010 07:23 PM
1BAD68"S"
January 15th, 2007 07:55 PM
