Proper Jetting for Street Use
I had a question on the major difference in stock settings between Pontiac and Oldsmobile. Comparing same size engines equipped with Quadrajets, the jet/rod combinations are very different. Pretty much all the jets used from 70 to 72 across the board on all V8 engines were .069 to .072. But the primary rods on Olds were considerably larger, making a much leaner part throttle mixture. All rod tips are the same at .026, so wide open throttle is unaffected, but for instance, a 1972 Cutlass 350 uses .069 jet and .050 rod, a 19 difference and that is the same for the 72 442 455. The 72 Pontiac uses .072 jets and .043 rod for 455, a 29 point difference. The numbers for 1970 higher compression engines are similar with the Pontiac engines much richer part throttle.
Anyone know why the huge difference? Is it the adjustment on the part throttle screw or the internal passages and orifices? I learned years ago that when you increased jet size, you usually needed to also increase rod size or the carb would be much richer for normal part throttle and lose it's responsiveness. Without the discussion turning into which brand is better, it seems to me that the mixture between the 2 brands should be similar.
The dark art of carb tuning is a science. There are additional variables such as float level, air temperature and altitude affecting this.
My thought is these factory carbs are setup to operate from sea level to Denver altitudes and somehow work! The first time buyer will never tweak it. So the two car makers may of had different ideas of how to spec what they were delivering across the US? The engines are very close where the jet/rod variations may yield nothing in the ol' butt-dyno? I think they just made a reasonable, do-all guess for the specs.
Carbs are best optimized to a specific location (altitude). A selection of jets and rods with considerable trial and error swapping may reveal the ideal setup for you is way off from either factory "do-all" spec.
Guess I don't know if your question is based on curiosity of the differences or you're planning surgery? I play with Edelbrocks 'cause Holley's are too fussy for me. But dialing any of them in is kind of fun if you're gonig down that road.
I am not planning any surgery, but own both a Pontiac 455 and a Cutlass 350. Both use very similar Quadrajets, but the jet/rod combination between brands is very different, and I was just curious. Both brands run fine.
In Doug Roe's book, he talks about jet and rod changes and cautions that you shouldn't make changes, calculated from the rod/jet combination that exceeds 5% (or was it 10%). I also posted on Cliff's site, and the answer seems to be because the internal circuitry between the brands is different and also has a big effect.
A simple answer is....Do you currently have a drive-ability problem? If so what is the symptom?
Before going at the carb, I (we all) suggest making sure all the simple stuff (ignition sys, timing events, vacuum leaks etc) is all checked and in known good order. Verify the float floats and its level and drop are in spec for your driving conditions and type of fuel you run. Clean air & fuel filter?
Next read the plugs and tail pipes. Determine which side of stoich your on, rich or lean. After determining which way you need to go then order an assortment of primary rods, secondary rods, jets, maybe a hanger or two and start playing. If you have the availability to put it on a chassis dyno that's the best way of dialing it in. But the trial n error method using the seat of your pants-n-eyeballs works with patience.
Be aware that the secondary vac door (butterfly) spring can weaken with age causing it to open to much/to early causing a rich bog when your going from PT (part throttle) to WOT(wide open). Thats a simple adjustment. So you see its important to know which circuit in the carbs causing the problem. Dont just throw parts at it or you WILL get frustrated.
The Quadrajet design was very flexible. It was used in everything from a 230 cu. in. Pontiac OHC six to a 500 cu. in. Cadillac , with variations in tuning and/or throttle size .
Actually the jet/rod combos for the Olds 350 & 455 are almost identical, as are the Pontiac 400 & 455. But the difference in the Olds vs. Pontiac is huge. The jet/rod difference in the Olds is 19, but it is 29 in the Pontiac. ( All rod tips are the same at .026, so wide open throttle is unaffected, but for instance, a 1972 Cutlass 350 uses .069 jet and .050 rod, a 19 difference and that is the same for the 72 442 455. The 72 Pontiac uses .072 jets and .043 rod for 455, a 29 point difference. The numbers for 1970 higher compression engines are similar with the Pontiac engines much richer part throttle.)
I state again, my Cutlass is running just fine. But since I also own a Pontiac with a 455, I noticed that the Pontiac has a much richer jet/rod combo, and was curious why so different for 2 similar GM products using a similar Quadrajet.
I think the solution to this puzzle lies in the different designs (duh), namely that the Olds engines are more torquey at certain RPMs and so forth. Look at the torque curve of each engine and you'll see a pattern, I think.
Which rpms are Olds engines more torquey? My 1970 Pontiac 455 is rated at 500 lb. ft of torque at 2700 rpms. I don't have the specs for a 1970 Olds 455, but I don't think it's much different. Olds, Pontiac and Buick 455s were ALL considered Torque Monsters.
This is the link I started. https://classicoldsmobile.com/forums...treet-use.html
... "a 1972 Cutlass 350 uses .069 jet and .050 rod,... the same for the 72 442 455"...
Okay that would be quite the spread of cubic inches across the 350-4XX range. Up to 100 c.i. difference! I would have bet money the carb spec would be richer for the big boys.
None of this makes sense and I'll contend the factory engineers back in the day were a bunch of lazy guessers. They used vacuum tube powered Dynos made out of wood that displayed random readings and graphs that only trained dolphins could decipher.
Engineering note: If the sucker runs well and can operate in various climates and altitudes, we're good. Ship it. Further testing is futile and the dolphin is mad.
You posted the classicolds thread, not the cliff carb site one. :/
I think it's incorrect to think a 455 needs to be richer than a 350. A bigger engine typically burns more fuel, but not because it is running richer, but because it has bigger volume cylinders. The carb mixes the air and fuel. A bigger engine will draw in more fuel and air. It doesn't need to draw in a richer mixture, only more of the correct mixture.
http://cliffshighperformance.com/sim...p?topic=1944.0
Very good point. The Q-jet only opens the secondaries as the engine breathes, I could see how the same carb could be used, but the exact same rods/jets? Even at idle, a 455 must use more fuel than a 350...
I don't think the fuel goes through the jets at idle, does it? I think it goes through the idle circuit. But even on the primaries, a bigger engine will draw more fuel/air mixture because of bigger cylinders, but the optimum mixture (rich/lean) should be about the same, assuming a similar compression ratio.
Gearman69, good info. In fact, the exact reason I started this thread was because I noticed the HUGE difference between the stock settings of Olds and Pontiac. I am much more familiar with Pontiacs, and have owned many through the years, but this is my first Oldsmobile. My 1972 350 is a street only car, that currently runs 69 jets and 50B rods. It starts and runs fine, but the question always comes up, if fine could be a lot better. With a low compression 350, I am going to try 70 or 71 jets and the 40-42 rods.
