ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Vehicle Lineup > Cutlass, 442, and Hurst/Olds > Cutlass
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old September 22nd, 2008, 12:27 AM   #1 (permalink)
Willidog
Official Tire Kicker
Willidog's Avatar
Tranny brackets and cable
Went to hook up my transmission tonight and found that the cable and bracket that bolts to the bottom of the pan would not match up. Background information is I got the car and it had a th400 transmission in it with no shifter, just the cable and brackets (the one that bolted to the bottom of the pan and the one that connects to the shift selector shaft. I kept the brackets and cable and sold the transmission. I have the th350 transmission that I dropped in the car and when I went to bolt on the bracket that goes to the bottom of the pan the bolts didn't line up and the cable would not work, it was either too long or too short depending on which bolts I had the bracket bolted to on the transmission (I bent the bracket to get it to line up with the 350 pan bolts.) The question is does the 350 use the same brackets as the th400 (I don't see how they could since I had to bend this one to get it to line up, but it did have some welding on it like someone had cut it in the past and rewelded it in a different spot) and is the shift cable the same length for each one or do I need to buy new brackets and cable? If so, where can I get them? Thanks. I forgot to mention the year and model. It's a 69 Cutlass 2 door hardtop with the Rocket 350 and a th350 tranny.
__________________
Willidog
Last edited by Willidog; September 22nd, 2008 at 02:19 AM.. Reason: Forgot to put year
Willidog is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old September 22nd, 2008, 07:49 AM   #2 (permalink)
joe_padavano
Super Moderator
Quote:
TH350 and TH400 use different shift cable brackets.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old October 5th, 2008, 01:05 AM   #3 (permalink)
Willidog
Willidog's Avatar
more problems
I got the correct bracket for the 350 transmission and it still doesn't connect properly. I have some pictures of the brackets that I have. The bracket that hooks onto the shifter shaft out of the transmission may be the problem but I would like to know for sure.
Here are pictures of the bracket that hooks to the shift shaft and the shift cable hooks up to, is it a bracket for the 400 or is it the same as a 350 bracket? When trying to hook up the cable it is about 1/4 inch to short so I have to put the transmission in reverse to hook up the cable, then the shifter only takes the transmission from reverse to low 2 (I think it's low 2, the first notch after drive).
__________________
Willidog
Old October 5th, 2008, 01:06 AM   #4 (permalink)
Willidog
Willidog's Avatar
continued
Here is the new bracket that hooks to the transmission pan and holds the shift cable.
__________________
Willidog
Old October 5th, 2008, 06:24 PM   #5 (permalink)
cruznn
My bracket is compleatly different than yours. I also have the 350 trans. Mine also hooks up to the backdrive linkage to the steering column at the same time as being hooked up to the cable also. Your pan bracket looks the same as mine. Also make sure you have the correct cable for the 350 trans. I am not sure they are different, but they may be. Also you can adjust the pin on the bracket where the cable hooks on by loosing the nut on the other side of the pin. Not alot of adjustment, but maybe enuf to make it work. Just my 00.2 cents worth of ideas. Hope it helps.
Mike
cruznn is offline   Reply With Quote
Old October 5th, 2008, 08:58 PM   #6 (permalink)
Willidog
Willidog's Avatar
Like this?
Does your bracket look like this??
__________________
Willidog
Old October 6th, 2008, 05:44 PM   #7 (permalink)
cruznn
Yes it looks the same. The way I installed mine was to put the car in park, swap out the bracket for the one in the pic. Make sure you block the wheels on your car first before switching brackets. I thought I had mine blocked good, but when I took the old bracket off I accidently shifted into reverse causing the car to roll over my arm. The pin is adjustable, but not by much. It is the only place to adjust from. The other bracket goes on the last two trans pan bolts closest towards the interior section of your car I Think? I can try and take pics of mine, but not untill thurs or fri
Mike
Old October 7th, 2008, 05:48 AM   #8 (permalink)
Oldsguy
Hot Rodder at heart Administrator
Oldsguy's Avatar
Quote:
Originally Posted by cruznn View Post
...but when I took the old bracket off I accidently shifted into reverse causing the car to roll over my arm.
Are you ok? Jeesh I would have dirtied myself I think.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
"The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB.
Oldsguy is offline   Reply With Quote
Old October 7th, 2008, 05:57 AM   #9 (permalink)
Jamesbo
Super Moderator
. I thought I had mine blocked good, but when I took the old bracket off I accidently shifted into reverse causing the car to roll over my arm. i
Mike
Ouch, second only to a fire extinguisher, a good set of chocks belong in every garage,
Hope you're Ok
__________________
69 H/O
69 442 convertible
69 Vista Cruiser
69 442 hardtop
"Growing old is mandatory,Growing up is optional"
Jamesbo is offline   Reply With Quote
Old October 7th, 2008, 06:03 PM   #10 (permalink)
cruznn
Thanks for the kind words. Yes I am ok, no broken bones, but it did rip a bunch of skin off and a little bit of bleeding and a whole lot of hurt! Like a true car nut I wiped it off as best I could and wrapped a towel around it and got back under the car to finish the job. This time I put my other car up against the back bumper to keep it from rolling backwards, front wheels were blocked as well. Can never be to carefull. Take it from me, take the extra time to be safe before starting your work!!!!
Thanks again guys!
Mike
Old October 29th, 2008, 02:44 PM   #11 (permalink)
Willidog
Willidog's Avatar
I got the correct brackets and the cable still doesn't fit!!
I E-MAILED BAP and asked them what the length of the cable is that they sell and they told me it was 31 and 1/4 inch eye to eye and 32 inches long overall. My cable is 30 inches long end to end (2 inches shorter than the one BAP sells for the turbo 350.) I know of course what really matters is the distance from where the cable hooks into the bracket to the transmission shifter, but with a different length cable I am wondering if the cable I have may have come off of a two speed transmission.
__________________
Willidog
Old October 30th, 2008, 09:37 AM   #12 (permalink)
Cutlass69S
Member
I replaced my 2 speed with a 3 speed and used the original 2 speed cable and everything worked, I just couldn't Manually shift down to 1st. hmmm......
Cutlass69S is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
371 ac brackets rays1930 Parts Wanted 0 August 1st, 2008 04:22 PM
a/c brackets Chumley Small Blocks 3 June 1st, 2008 09:07 PM
65-67 olds400 brackets jrmorte Parts Wanted 2 May 10th, 2008 09:49 PM
Alternator brackets 74 Omega Parts Wanted 6 April 19th, 2008 10:28 AM
Tranny fluid coming out of kick-down cable inlet scrappie Transmission 0 April 9th, 2008 06:17 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
