intake manifold swap
Ok I'm a newbie, pardon my ignorance, I'm learning quickly though. Converting a 70 olds supreme without a/c to with a/c. Need to move alternator to right side from left side. Also replaced stock cast 2 barrel intake with aluminum a4 intake from a 307. Trouble is, with this switch I lost the bolt up spot for the alternator bracket on the intake manifold, as the a4 intake does not have it! So what brackets do i use to mount the alternator on the right side? Help please
that gave me trouble, this was when I was marking where to drill.
Bill
intake swap
thanks for the replies, not sure where I'm going to go from here. Don't want to go with a stock cast 4 barrel intake as my first choice cuz I hear they don't flow as well. May try the performer 3711 intake and move the hole as needed. Just not sure yet. Thanks again,
The problem is, you have a 1970 model and that taller steering pump reservoir is not compatible with the alternator brackets that will match the A4 intake. I just went through this fiasco 2 weeks ago.
I ended up modifying a 79 Ford econoline smog pump bracket for use as an Olds alternator bracket.
manifold swap
thanks again, thinking of going with a performer intake and a large "C" shaped bracket i've seen on other cutlasses with 350's that bolts directly to the front of the block and then an "H" shaped bracket for the back. I think this will work. If not, then back to the drawing board. May have to change the power steering reservoir too. Oh...this is so much fun...not!
If you have the correct brackets then it will bolt up fine. I had both the Performer 350 and Performer RPM on my engine (with AC) and everything lined up perfectly. It's the Performer 455 that needs the hole (or the bracket) modified.
Unless, of course you don't have stock valve covers. The H shaped bracket wraps over the valve covers. If yours are taller you will run into trouble.
Decisions decisions. Changing the pump reservoir to a 72 model and 80's 307 alternator brackets would be easier than changing the intake in my opinion, If you had them laying around already.
but you would probably have to track that stuff down and spend money of course.... thus making it not easier.
I would just leave the dang top bolt out and run what you have. I highly doubt it's going to twist itself into a pretzel.
manifold swap
thanks for all the replies again. Yes I have stock valve covers so those brackets should work. Trouble is, now I'm having trouble finding those brackets. They seem to be kind of hard to come by. Any help here would be appreciated. Going to go with a performer intake, used ones are abundant and not too expensive. Will post pics when the project is more complete. Thanks again.
shamusj
December 18th, 2014 09:28 AM
wcourt3010
October 2nd, 2012 12:50 PM
'69CutlassVert'
August 25th, 2011 07:19 AM
svnt442
July 17th, 2011 04:43 PM
