Go Back   ClassicOldsmobile.com > Vehicle Lineup > Cutlass
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 02-06-2008, 12:50 PM   #1 (permalink)
69sAndrew
69 Cutlass S hardtop
Sandblasted chrome
Hey guys I have some chrome parts of the 69 that I am getting done with a process called super chrome. Basically, it's just a powder coated chrome process. My question is, a few of the parts have some pits in them. I need to fill them and was wondering what to use. It has to be able to withstand 350 degree heat.
I was thinking of a product called liquid steel, but I am open for suggestions.
Thanks,
Andrew
69sAndrew is offline   Reply With Quote
Sponsored Links
To remove this ad, register today!
Old 02-06-2008, 04:43 PM   #2 (permalink)
Olds64
Landyacht Club President
As far as I know you can't add any type of filler to the metal bumper before you have it chromed. If you used something like bondo it wouldn't work because chrome is an elctro-chemical process that bonds a coating onto the metal of the bumper (or piece being chromed). If the piece you want to chrome has pitting then I think it needs to be buffed out before being coated. If it is too deep then see if it can be cut out and a new piece welded in to replace it. Then again, this might be so complex that you would be better off buying a better piece to chrome.
I have heard of a paint that can be sprayed over just about anything that has a luster like chrome (not the cheap rattle can stuff). I believe I saw it on one of those Chopper shows on the Discovery channel. It is a paint that is sprayed on in multiple layers and it looks really good. Just a little darker than normal chrome.
__________________
"Some men are Baptists, others Catholics. My father was an OLDSMOBILE man." Ralphie Billingsley A Christmas Story 1983
"We rei-eign, supreme, ooooh god! Burrito supreme, and a chicken supreme, and a CUTLASS SUPREME!" Tenacious D 2007
Olds64 is offline   Reply With Quote
Old 02-06-2008, 07:35 PM   #3 (permalink)
Dynamite
Junior Member
I had just seen that chrome paint in the Eastwood catolog. Anyone have any experiance with it? Chrome in a can, sounds too good to be true.
www.eastwoodco.com
__________________
1965 Dynamic 88 Conv
Dynamite is offline   Reply With Quote
Old 02-07-2008, 02:59 PM   #4 (permalink)
72Cutlass
Member
Actually there is a product that you can use with the powder coating process that it will stick to, but the name escapes me at the moment. Do a search on the eastwoodco.com forums and Im sure you can find it...the company will send you a sample if you contact them(big enough to do your trim and some).
72Cutlass is offline   Reply With Quote
Old 02-08-2008, 09:46 AM   #5 (permalink)
69sAndrew
Well the process this guy uses in not electromagnetic. It is called super chrome and uses a powder coat technology. I just need to fill the pits and it has to hold up to 350 degrees for 10 mins. I have found a product that I will try this weekend. It is a liquid weld that is good to 800 degrees. I asked the guy and he said this should work. When I get the parts done, I will try to post asome pics.
Old 02-08-2008, 10:02 AM   #6 (permalink)
Olds64
Hmm... I look forward to seeing the results. I have never heard of this before but it sounds pretty cool. Let us know what you think of the results. Good luck.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
need all 4 chrome 14 in Cutlass rallys HAFROD Parts Wanted 3 05-29-2008 04:59 AM
Chrome Cecil Anderson Cutlass 1 02-06-2008 08:48 AM
chrome Cecil Anderson Cutlass 0 02-06-2008 08:28 AM
chrome plating mr-tom 442 1 03-16-2007 09:28 PM
69 wheel well chrome Want-A-Vert Parts Wanted 1 02-13-2007 11:48 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
