| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Senior Member
Quick question on air shocks
I have a 72 cutlass with air shocks on the rear...what are the pros and cons for using this system. Thanks,
Sam |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
They help compensate for a smoother ride, and are awesome for when you load it down for a road trip. I had them in my 73 Cutlass, and they will be in my 80 when it's done. Only bad part is the need for a compressed air supply. Hope this helps.
#3 (permalink) |
Super Moderator
The downside to air shocks is that the frame is not designed to carry the weight of the car through the attachment point at the top of the shock. I would recommend air bags instead. The bags go inside the coil spring and thus the load path is the same as the factory intended. Functionally they are identical to air shocks.
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#4 (permalink) |
Senior Member
I'm not ever planning on having the car weighted down, so that's not a big deal for me. What I do like is a smoother ride, but does it has any adverse effects on handling? I'm planning on mostly cruising/racing this car. Thanks
#5 (permalink) |
Hot Rodder at heart Administrator
I think it is about like tires. Performance tires that handle better are going to provide a harsher ride and conversely passenger tires that have a nice soft ride are going to be very weak on performance. So, shocks valved for stiffer performance will naturally feel harsh, and shocks valved for a nice ride will not provide enough performance for people who want to "push" the envelope. It is hard to get both in one shock, although I know many advertise they do.
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
#6 (permalink) | |
Super Moderator
Quote:
Gas shocks have an internal nitrogen-pressurized bladder that is designed to prevent the shock hydraulic oil from aerating while driving. This is a good thing.
__________________
#7 (permalink) |
Super Moderator
This is mainly due to sidewall height. Performance tires tend to be low-profile, which means shorter, stiffer sidewalls.
__________________
#8 (permalink) |
feed the pig
I have used airshocks for years. I have to admit they do give a harsher ride, but can't say they effect handling in any negative way.
I have heard others talk about wheel hop when launching, but I don't have that problem. I like the ability to adjust the ride height when running loaded. Only other con I can think of is the plastic airlines that feed each shock. They could melt if installed too close to the exhaust, or get pinched. Either way, the air excapes,then the rear droops and you are riding on the bouncy bouncy springs. I carry a spare line, just in case.
__________________
1971 Cutlass S Holiday coupe-455/th400 3.23 Oldsmobile they were meant to be driven. |
#9 (permalink) | |
Quote:
__________________
#10 (permalink) |
Senior Member
Yes, I am talking about the air shocks that were an option on my 72 cutlass. I have them, and was just wondering what the pro's and con's were. Basically I wanted to know if they were acceptable for all around driving, or if they are exactly the same and a regular shock except for the fact that you can adjust the ride height...which is awesome. Thanks
#11 (permalink) | |
Super Moderator
Quote:
__________________
#12 (permalink) |
I have airshocks on my 70 and only run 20 lbs in them and they act just like regular shocks BUT if i had to do it over again i would use airbags.
#13 (permalink) |
Back in '77 I had a set of Gabriel "Hijackers" on my '70 SX. I had them filled just enough to get that "jacked up" look that was so popular back then. Never had any problems whatsoever. A Supreme was not really designed for performance handling anyway, and I didn't try to make it do so. Of course we didn't have the modern technologies like air bags back then, so today there are a lot more choices. As I recall, I still had one of the smoothest riding muscle cars among my peers. Today I would probably go with air bags, since there seem to be advantages over air shocks as has been noted. Chumley
#14 (permalink) |
Landyacht Club President
In an airbag suspension doesn't the airbag simply replace the spring? I though you had to reposition the shock and anchor it to a different point. In other words, don't airbag suspensions still use shocks?
#15 (permalink) | |
Super Moderator
Quote:
Yes, airbags just replace the springs. There are some street rod airbag systems that mount coaxially with the shock. You can get aftermarket air bags that go inside the rear coil springs for additional load-carrying capacity. The advantage over air shocks is that the air bags transmit the load to the reinforced parts of the frame and spring perch. Air shocks transmit this load through the shock mounts, which are not as strong.
__________________
#16 (permalink) |
since both will give you the jacked up rear end, which is cheaper ? because im gonna get some lol
__________________
69' Cutlass 4 door. Built 455 inside, grandma's grocery getter outside. Best sleeper in disguise.
#17 (permalink) |
If you jack up the rear end in your '69 it won't look so much like a sleeper anymore......
__________________
#18 (permalink) |
Air shocks would be cheaper.
__________________
Ferris, my father loves this car more than life itself... Apparently, you don't understand! Ferris, he never drives it! He just rubs it with a diaper! Cameron Frye Ferris Bueller's Day Off 1986 |
#19 (permalink) |
Seasoned beater pilot.
I don't think a 69 could be a sleeper, period.
People expect a lot when they see a car like that nowadays. For many on lookers, if it doesn't live up to the muscle car legend, it's just an old clunker. A good sleeper would be a 1990 Woodgrain Custom Cruiser with rust bubbles the size of your head, and 4 non matching rims, that does 11s.
__________________
#20 (permalink) |
member
you guys should look into a performance air bag system i suggest looking into air ride technologies at ridetech.com, im saving some money to get it myself because its a bit pricie.
#21 (permalink) | |
Quote:
__________________
#22 (permalink) |
Senior Member
It turns out now that my airbag/shocks/whatever they are...leak. I pumped them all the way up monday night, and this morning they are down again. Is there any place that they generally leak from or do I need to get my squirt bottle filled with bubble solution out?
#23 (permalink) |
If you have an airbag suspension then I suggest you check the bottom or top of the airbags where they contact metal. Airbag suspensions are notorious for collecting rust in that area and losing air. Have you ever seen a late 90s Lincoln Town Car cruising down the road with the rear bumper practically dragging on the ground? (that is due to bad airbags)
If you have air shocks and they are leaking I suggest checking your lines that go into the shocks. They could have kinked and split apart. That would be the easiest thing to check too.
__________________
#24 (permalink) |
I had airbags (in the coils) in my 87 Grand National and only pumped them up to launch off the line racing. My buddy had airbags (in the coils) in his Ford F250 truck to level out when carrying his camper.
My airbags cost $75. With airshocks, you may as well get rid of the coils since they're not doing anything (not recommended of course).............. Only 2 small bolts (5/16" or so) hold each air shock in place so the stress on those mount points are high. Remember that with one line to your 2 airshocks, you get more body roll than if you have 2 separate lines. Some older racers put an airshock on one side to keep the car straight during racing launches..typical in old Challengers/Cudas.
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| interchangeable shocks for jetstar1 | mojorison | Chassis/Body/Frame | 1 | July 11th, 2007 05:44 PM |
| Quick starting question.. | buddiiee | Cutlass | 4 | January 10th, 2007 05:40 PM |
| Quick Omega question | coldfire | Other Oldsmobiles | 5 | January 10th, 2007 02:02 PM |
| '63 Dynamic Rear Shocks | aristellier | Eighty-Eight | 1 | December 19th, 2006 04:51 PM |
| 57 Olds upgrades completed but now need shocks - help | J'ville | Eighty-Eight | 1 | August 19th, 2006 02:07 PM |
