high beam light won't switch off, which relay is responsible
Old December 28th, 2011, 03:20 AM
Cutlass driver in Germany
craftsmen22's Avatar
Hi,
when I use my high beam lights on my 69 Cutlass conv. the relay responsible for switching of won't do so. I already replaced the foot switch, but no success. So now I need to know where the relay sits and which new relay to use.
Best regards,
Tom
craftsmen22 is offline
Old December 28th, 2011, 03:51 AM
Originally Posted by craftsmen22
high beam light won't switch off, which relay is responsible?
None.
  • Big red wire goes into headlight switch,
  • Blue wire comes out, goes to dimmer switch,
  • Brown wire from dimmer switch goes to low beam filaments,
  • Green wire from dimmer switch goes to high beam filaments.
That's it.
MDchanic is offline
Old December 28th, 2011, 06:43 AM
'87 Delta 88 Royale
rustyroger's Avatar
Have I got this right; when you switch on your headlights you only get high beam?.
Either the dimming switch is incorrectly wired or the new switch is bad. American cars, particularly older ones didn't use relays much, one less thing to go wrong but more current passing through the switches.
Check for 12 volts to the light switch, then to the dim switch, then from the dim switch in both modes. You should get voltage to one and nothing to the other alternately as you operate the dim switch.
Roger.
rustyroger is offline
Old December 28th, 2011, 08:31 AM
jackedolds's Avatar
Be sure to check for terminals that are dirty or have lost tension in the dimmer switch plug. If they are dirty or have lost tension you can probably remove the metal terminal from the plastic connector, clean the connection point, "adjust" the terminal so that there is appropriate tension, and re-assemble.
Easy way to identify the dimmer switch as the culprit is to unplug it and use a jumper wire and the above provided wire color code to jumper the dimmer switch connector to see if the appropriate lights come on. Caution - do not use a paper clip, or if you do then hold it with pliers and only make the connection briefly. The dimmer switch will have the full current of the headlamps going through it, and so will your jumper. Paperclips get hot fast (just ask my thumb and first finger) :-) Also - while I don't have the intricate knowledge based on model year that some on this forum do (and I willingly admit this), I thought that on low beams only the outer 2 bulbs are on and on high beams all 4 bulbs are on? Is this correct (aimed at one of you with specific model year knowledge).
jackedolds is offline
Old December 28th, 2011, 09:05 AM
Oldsdruid
rocketraider's Avatar
Notice that Tom is in Germany. The car may have had some wiring mods done to meet German lighting requirements esp if high-powered halogen lamps were installed.
Tom, American-spec car will not have a relay in the headlamp circuit. Short of knowing what modifications were done for Euro lighting standards, best I can tell you is trace the wiring back from the headlamps and dimmer switch and see if a relay has been installed.
rocketraider is online now
Old December 28th, 2011, 09:24 AM
European lighting standards require each low- or high-beam to be on it's own independent fuse.
If he's got that setup, they could have done it dozens of ways, and there's not much we could say to help.
And, yes, Jack, low beams should light the outer two bulbs, high beams should light all four.
MDchanic is offline
Old December 28th, 2011, 10:17 AM
Hi, and thank you for so many replays. Sorry for not pointing out the problem more correctly.
I switch on regular headlights everything is fine. Then on a free track I turn on high beam by stepping on the foot switch besides the pedals. Now a car comes towards my direction. I press the foot switch again, I hear the click, but the lights won't dim down. So I turn lights off by using the light switch besides the steering wheel. Lights go off, and once I turn headlights on, everything is fine.
About German law and headlights: I only had to change the seal beam lights to German standards, so I used lamps where you insert a h4 bulb, so in case a rock smashes the seal beam it's death, and the bulb on mine is still working in case of impact. So wiring is the same as before, I have just no idea to get the high beam working correctly.
And yes, the high beams are the two inner lights, on my signature picture you see the two lights which are off - these are my high beams.
Thanks so much for your participation on my problem,
regards,
Tom
Old December 28th, 2011, 10:36 AM
If the original wiring has not been modified, then the problem has to be in the highbeam switch, from what you describe.
MDchanic is offline
Old December 29th, 2011, 08:56 AM
'87 Delta 88 Royale
rustyroger's Avatar
Not on a car that old, some British cars of that era had only 2 fuses, one for ignition live circuits, another for permanent live circuits.
Not a great idea I know, but thats how it was.
Roger.
Old December 29th, 2011, 10:01 AM
Originally Posted by rustyroger
Not on a car that old...
Hmmmm...
I've had two '70 911s, and they each had four fuses for the headlights: one each for Right Liw, Right High, Left Low, and Left High
I always thought it was because they had to.
MDchanic is offline
Old December 29th, 2011, 10:10 AM
'87 Delta 88 Royale
rustyroger's Avatar
You had a high end car Eric, I was referring to BMC and late '60s Fords.
Fiat, although making cheap cars, put a very good fuse system in their cars.
Roger.
The Flash
May 31st, 2014 07:19 AM
woody30
Tech Editor's Desk
September 15th, 2012 08:45 AM
scott71
June 18th, 2011 07:04 PM
kandelino
November 5th, 2010 06:45 AM
BaileyJD1
May 1st, 2008 11:45 AM
Quick Reply: high beam light won't switch off, which relay is responsible
