| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
'72 tail lights
On these tail lights, do the stop lamps(bulbs) go on the top or bottom holes of the housing? Also, are both lamps supposed to be on when running lights are turned on? When I turn the switch on, both bulbs are lit, one bright and one dim. Is this correct? I don't want to create an electrical problem if this is not right. Thanks, Chumley
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) | |
Super Moderator
Quote:
The 1157 is a bayonet base bulb with two contacts on the base. The bayonets are offset so the bulb can only be inserted one way.
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#3 (permalink) |
Thanks, so are you saying that with the running lights on(no brakes or turn signal on) that all four bulbs should be the same brightness? And when the brakes and/or turn signal is on, both lamps(whatever side turn signal is on) both lamps should turn on and off at full brightness? Right now, with just the running lights on, one lamp is bright and one is dim.(same for both sides) I guess I'll just get a new wiring harness, I know the one in there is not correct. Also, are those lamp sockets acting as a ground against the back of the housing? Thanks Chumley
#4 (permalink) | |||
Super Moderator
Quote:
Quote:
Quote:
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1972 Cutlass Tail Lights Question..... | Eightupman | Chassis/Body/Frame | 9 | January 13th, 2007 04:59 PM |
| tail lights | lee32680 | Alero | 2 | December 29th, 2006 02:48 AM |
| 66 442 tail lights | dreeser1 | Parts Wanted | 0 | October 19th, 2006 11:18 PM |
| change tail lights '84 delta 88 | ztim | Eighty-Eight | 5 | October 7th, 2006 03:18 PM |
| my rear tail lights | diablo76delta88 | Big Blocks | 1 | August 10th, 2003 10:15 PM |
