| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
69 convertible with rust!!!!!!!!!!!!!!!!!
Hello all,
well this weekend i removed the wind shield ( it was cracked) and the top and the bottom frame were the glass sit is all rottrd out YUCK!. ok my question is i have a parts car a 4 door cutlass is the windshield fraqmes the same?? pillars and all? Thank you all , in advance Troy ![]() |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Junior Member
69 with windshield rust
can any one help with this question, I think it will work but want some re assurance .
Thanks Troy. |
#3 (permalink) |
Junior Member
Troy,
When I had the windshield replaced on my '69 442 convertible, the shop told me it was a shorter height than the hardtop by a couple inches. Cheers! Murray
__________________
Make your escape from the ordinary. Oldsmobile 442 1969 442 Convertible 1983 Hurst/Olds |
#4 (permalink) |
Hot Rodder at heart Administrator
I agree with Murray, the header panel on the convertible is different becaus it has the hardware to attach the top so it is different in that respect too. You might do better to have someone that knows metal work to repair those channels with replacement steel. You said rotted out, do you mean in patches and pieces or ALL THE WAY AROUND? If it is the former it can be repaired, the latter....kiss the car goodbye or get a whole new frame from another convertible.
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
#5 (permalink) |
Junior Member
First Thanks mur and oldsguy for the response.
I guess what i'm asking if i cut out the rusted area like the cowl area they should be the same to weld back in? and the top if i cut pieces I should be able to do the same !! the rest of the car is in fair shape, small holes in trunk and floor boards. not bad for a new england car!!!! thanks Troy. |
#6 (permalink) |
I would think that would work and it would be better than using generic pieces of stock metal.
__________________
| Thread Tools | |
| Display Modes | |
