ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Vehicle Lineup > Cutlass, 442, and Hurst/Olds > Cutlass
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old February 20th, 2007, 05:54 PM   #1 (permalink)
Mr. King
Member
Mr. King's Avatar
1966 Cutlass tuning question
I have a 1966 Cutlass with a 330, a 4 speed, 2 1/2 inch dual exhaust and posi rear with 3.55 gears. The motor is basically stock with a slightly larger than stock cam, an Edelbrock performer intake and a Edelbrock 650 carb.
The motor just doesn't seem to have any bottom end. It is very slow to rev and the motor doesn't really "come on" until 3500 rpms. Plus, it seems to "miss" at lower rpms.
I'm considering changing to a HEI points conversion. Anything else I should check or change. I set the timing to the stock settings and the carb is set just a little rich. The motor sounds great with a slight lope but it just doesn't pull like it should.
Any suggestions?
Mr. King is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old February 20th, 2007, 06:23 PM   #2 (permalink)
Oldsmaniac
Oldsmaniac's Avatar
What you are experiencing seems exactly like an over camming problem. You loose all bottom end acceleration. The 2 1/2 inch exhaust doesnt help either as you are loosing backpressure. I would suggest you do a tune-up with new plugs, points, rotor, cap, and maybe wires. Then set timing to specs or advance it a little. If the engine pings on premium you have advanced the timing too far. also check any vacuum lines for leaks and make sure the carb is bolted tight so the base gasket isnt leaking.....
Oldsmaniac is offline   Reply With Quote
Old February 21st, 2007, 05:45 AM   #3 (permalink)
Mr. King
Member
Mr. King's Avatar
From what I understand the guy that rebuilt the engine before I bought it put the W30 or W31 stock cam in it. I think that's the 400 442 cam. So it's not TOO radical.
I have a feeling I have a vac leak because I hear a "sucking" sound, but I can't find a vac line that is off or split. Any ideas?
Also, I forgot to mention it's hard to start. I have to crank it several times and then sit for 5 minutes reving it until it will idle.
Old February 21st, 2007, 11:45 AM   #4 (permalink)
number9
Junior Member
Quote:
I can't help you with specifics, but the way of finding bad vacuum lines that I hear most is to spray carb cleaner on lines you suspect might be bad while the car is running. If the RPMs go up, then you've found a bad line (or some other kind of leak).
number9 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
