ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Vehicle Lineup > Cutlass, 442, and Hurst/Olds > Cutlass
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old January 19th, 2007, 11:45 PM   #1 (permalink)
curvewrecker
Junior Member
77 Cutlass 455 swap
I have a 1977 Cutlass supreme with a 403 and a TH350. After deciding to rebuild the 403, I came upon a newly rebuilt 455 at a price I couldn't refuse.
Its a 72-76 "Fa" block, has E heads, a 1975 iron intake (412753) .040 over pistons, a 204/214 280/290 cam, and probably 8.6:1 compression.
I have no exhaust manifolds, flywheel, water or fuel pump, or carb.
Can I swap these parts form the 403? It has a new edelbrock 600 carb on it, would this be too small, or would it do until I can afford a bigger one?
I'm looking at Blackjack 85029 headers, has anyone used these and do they fit well?
I just bought the car and engine this month, and am new to the Olds V8s.
curvewrecker is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old January 20th, 2007, 07:53 AM   #2 (permalink)
texasred
Tom Servo's Stunt Double
texasred's Avatar
Curve,
Small block exhaust manifolds will physically fit, but they'll be too small to flow well. I think you'll find the Hooker Comp (not Super Comp) headers fit well.
Small block and large block intakes will not swap. You hould be fine on the fuel pump. Flywheel, too.
600cfm is too small...plus I don't think you can beat a QJet. I've run Ebrocks squarebores and not been happy with their low/part throttle response after a LOT of tuning.
I'm having a street/strip 455 built right now. I'm having my TH-350 freshened and slightly beefed to run behind it. It's got better gears than a TH-400, leaches a lot less power, and I don't have to change my drivehaft.
JMHO.
C.J.
__________________
Dad said, "Sometimes you read Job...sometimes you ARE Job!"
texasred is offline   Reply With Quote
Old January 20th, 2007, 08:23 AM   #3 (permalink)
2blu442
2blu442's Avatar
Curve, where are you located? Posting the city and state may provide the parts you need from right across town! John
__________________
1964 Cutlass Factory 4spd
1965 442 4spd
1967 442 Auto
1967 Cutlass Convertible
1967 Cutlass four door daily driver
1968 442 Auto
1969 442 W30 Auto
1970 442 4spd
1971 Cutlass Flat Top Wagon
1973 Che*vy 3/4 Ton 454/TH400 Tow Vehicle
Only the tow vehicle is finished!
2blu442 is offline   Reply With Quote
Old January 20th, 2007, 10:31 PM   #4 (permalink)
curvewrecker
Junior Member
I'm South of Green Bay, Wi.
Old January 24th, 2007, 07:26 PM   #5 (permalink)
2blu442
2blu442's Avatar
Years ago I bought a 1977 Cutlass that had a 455 TH400 transplanted in. It had the 442 dual exhaust manifolds, the W and Z and they fit fine. It also had a Toronado intake which allowed the hood to close without any clearance problems. I've heard that the Toro intakes arn't good for performance, but this car had 1970 W30 heads on it with a 2.41 posi rear end. Not impressive off the line, but once up to 30-40mph it went to 100 really quick! So... if you had good heads and better gears it might be fine for a street car. I really don't know if other intakes would have clearance problems, I just know this was the setup I had. John
__________________
1965 442 4spd
1967 442 Auto
1968 442 Auto
1969 442 W30 Auto
1970 442 4spd
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
