69 Cutlass Exhaust (headers)
Hey Guys, I have recently purchased a nice 69 Cutlass Convertible numbers matching 350. It has some minor mods, cam, 2" exhaust, upgraded carb... but it does not have headers. After doing some research I see that most don't make headers for the 69' Cutlass but I assume (could be wrong) they would be the same as a 69' Chevelle with a 350. So i went to Jegs and looked online but all the Hooker Ceramic models i looked at say they don't fit on a 350 with a floor shifter. Do any of you guys run a similar setup and have headers? I am interested in headers because the motor feels super strong and has the 2" exhaust but i feel that some back pressure might be robbing me of some power. Any insight on all the subjects would be greatly appreciated. Thanks
As for "don't make headers", you need to brush up on your "research", Summit lists about a dozen headers for the small block Olds in an A-body. Ignore any footnotes that might say "don't fit convertibles" or "don't fit Supremes". We've been unable to kill those urban myths for decades. The only problem you may have is with the linkage from the steering column to the trans.
Ok Joe, Thanks for the info. I did go to Summit after reading your post. I had been shopping Jegs and they didnt seem to have anything to fit the Olds. I have found the Flowtech and Hooker headers at Summit that say they fit but the note states they don't fit the model with the floor mounted automatic transmission. So your telling me to ignore that note? The Hooker footnote says it doesnt fit the Cutlass S.
https://www.summitracing.com/parts/b...-size/5-7l-350
https://www.summitracing.com/parts/h...-size/5-7l-350
June 3rd, 2019 11:53 AM
69CulassConvertible
May 27th, 2016 05:59 PM
