ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Vehicle Lineup > Cutlass, 442, and Hurst/Olds > Cutlass
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old February 10th, 2009, 11:38 AM   #1 (permalink)
hinz57
hinz57's Avatar
Dual Gate vs. Automatic console
1972 Cutlass Supreme. Just want to verify the fact that the dual gate console is the same as the automatic console except for the top plate (and shifter of course). Is that correct? In other words I can use my existing automatic console and switch out the shifter and top plate and it fits right in? Is this correct? Any help would be appreciated...
Thanks,
Chuck
hinz57 is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old February 10th, 2009, 11:43 AM   #2 (permalink)
Jamesbo
Super Moderator
Which year car?
__________________
69 H/O
69 442 convertible
69 Vista Cruiser
69 442 hardtop
"Growing old is mandatory,Growing up is optional"
Jamesbo is offline   Reply With Quote
Old February 10th, 2009, 11:45 AM   #3 (permalink)
hinz57
hinz57's Avatar
I guess that would help. 72 Cutlass Supreme.
Old February 10th, 2009, 11:55 AM   #4 (permalink)
Eric Anderson
Eric Anderson's Avatar
Yes you trim it on the factory marks at the shifter area.
I'll take a couple before and after pics for you if you want.
__________________
My70Cutlasshe who has the most toys when he dies...wins
Eric Anderson is offline   Reply With Quote
Old February 10th, 2009, 12:05 PM   #5 (permalink)
hinz57
hinz57's Avatar
that would be a great help. Thanks Eric.
Chuck
Old February 10th, 2009, 12:38 PM   #6 (permalink)
Eric Anderson
Cut at the blue lines note the notch on the side where the light is this is where the tab on the top plate will end up. You will see the indication of where to cut it out on the backside of the console. I like to use a dremel type tool with a cut off disk for this type of thing, you have alot of control, then take a file and clean off the rough stuff left behind. Hope this helps you out.
__________________
Old February 10th, 2009, 02:36 PM   #7 (permalink)
hinz57
hinz57's Avatar
This is perfect information. I can't believe I got such a quick response & with such useful information. How did you get your plastic chrome trim on your console looking that good. Mine needs serious help.
Thank you very much for your input...
Old February 10th, 2009, 08:13 PM   #8 (permalink)
Eric Anderson
No problem glad it helped you out.The center trim with the woodgrain is the only plastic trim, they repop that, that being said on this site there is a thread about a new chrome spray paint I'm going to try that on mine as well as the gauge trim, if it works out it be be a pretty cost effective solution. The large trim around the whole console is aluminum that has tabs you straighten out on the inside, the trim around the compartment, which is also aluminum, is held on by little plastic rivits inside the box they usually get mangled getting them out I replaced mine with some I got off an electronics supplier they worked perfect. The trim on the compartment was rough so I lightly sanded the the really rough spots with super fine sandpaper then I polished it with a buffing wheel repainted the black stripe then gloss cleared it the large trim I just polished and cleared, don't think that is the correct way to do it but it came out pretty good, mabey someone else will chime in with a better way to take care of that.
__________________
Old February 11th, 2009, 01:43 AM   #9 (permalink)
Bluevista
Cruisin' the Vistas
Bluevista's Avatar
Hey Chuck. I did see this diagram in my '71 factory assembly manual if you need another point of reference. It looks like Eric has everything well under control here though. Pics really are worth a thousand words.
Is this the same deal as the '72? Says W26 console cut.
Allan
Bluevista is online now   Reply With Quote
Old February 12th, 2009, 10:40 AM   #10 (permalink)
hinz57
hinz57's Avatar
chrome paint
hey Eric, what thread are you referring to? I tried to find it but could be here for hours. I would love to find a chrome paint for plastic that looks good.
thanks,
Chuck
Old February 12th, 2009, 11:08 AM   #11 (permalink)
Eric Anderson
This one, looks like pretty cool stuff.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
What does this Dual Gate fit? mudjnky 442 17 January 14th, 2009 09:02 AM
Dual Gate A/T Shifter cbogartjr Transmission 11 August 28th, 2008 04:34 AM
66 Cutlass automatic console Rusty Boltz Parts For Sale 4 May 24th, 2008 11:27 AM
69 automatic console plate bigbrother Transmission 3 July 16th, 2007 07:27 AM
65 automatic console and aftermarket shifter??? denis Interior/Upholstery 1 February 23rd, 2007 12:51 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
