Another Jeep box question
Old June 28th, 2013, 01:38 PM
miked's Avatar
I have been reading all the posts about upgrading to a Jeep steering box and have decided to try that. I lucked into a neighbor's wrecked 96 Cherokee (NOT A GRAN) for 25 if I remove it. I felt it was worth it..has high miles but no leaks and wasn't damaged in side impact. I degreed the sweep and it is 25-26 degrees which puts it at about 14:1. Do you guys feel this is enough of a change to be worth the trouble or should I wait until I find a 12:1 box? BTW what is the stock ratio for my 67? Feels like about 50:1. I kind of think I want to try it and once I get the rag joint and hose adapters then a future change should be easier. I'm not necessarily after auto-cross handling just a more modern feel. Kind of tough when you drive a rack/pinion car every day then get in the no-feel, no centering, finger driver! Thanks for opinions!
miked is offline
Old June 28th, 2013, 02:05 PM
garys 68's Avatar
Not sure if that box will work at all.
Just get one in that's listed in the 100 threads out there. They're only $50 at the yards.
Every thing you'll need.
https://classicoldsmobile.com/forums...t-my-64-a.html
garys 68 is offline
Old July 1st, 2013, 08:59 AM
miked's Avatar
After more thought I think you are right...probably won't work (the input shaft has a flat on it since it used a u-joint instead of a rag joint). The Gran Cherokee is the way to go. Thanks for your input.
miked is offline
Old July 1st, 2013, 09:25 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Get yours rebuilt with the "modern feel" upgrade. Many have done so and have been very happy. Plus no adapting anything.... stock case... all bolts right back together.
droldsmorland is online now
Old July 1st, 2013, 10:53 AM
The Cherokee and the Grand Cherokee used different steering boxes.
That one will not fit your car.
MDchanic is offline
Old July 1st, 2013, 05:48 PM
jag1886's Avatar
I still say call Power Steering Service in Missouri, they rebuilt my box and pump last winter and installed 12.7 ratio, revalved everything to work together and also rebuilt my rag joint.
They are a more expensive than putting Jeep parts on your Oldsmobile but it's done right and you are putting the same box and pump back on your car that you took off and it's as close to rack an pinion as you can get without rack and pinion.
I love mine, it works perfect and made my old car steer like a new car.
jag1886 is offline
Old July 1st, 2013, 06:46 PM
Originally Posted by jag1886
They are a more expensive than putting Jeep parts on your Oldsmobile but it's done right...
Are you saying that using an inexpensive used Saginaw box from a Jeep is doing it wrong?
MDchanic is offline
Old July 2nd, 2013, 05:43 AM
miked's Avatar
Thanks Eric. Guess I got a box to sell now or use for core on a Grand box.
miked is offline
Old July 2nd, 2013, 05:45 AM
miked's Avatar
I like this idea too except for the down time. How long did it take to get this done?
miked is offline
Old July 2nd, 2013, 06:19 AM
oddball's Avatar
I was looking at using PSS, but went with a rebuild Jeep box. My only concern is whether or not the rebuilders did a good job. So I got an AC Delco rebuild, hoping they do at least a little more QA than Cardone.....
As with everything, there are a lot of ways to do it with a wide range of prices. And as is common, lower price = more risk.
oddball is offline
Old July 2nd, 2013, 08:58 AM
72 Olds CS
RetroRanger's Avatar
I picked up a rebuilT lifetime warranty lares unit from rockauto. It's a quick ratio form fit replacement and comes w a new rag joint. You use the original PS hoses and it bolts right in lares is a US company....it's about $200 , less if you return the core....look up your car on rockauto and see the options lares 974
I've got about 1500 miles on it and I like it the feel is very good not far from my rack and pinion DD.
I would recommend it, looks like new,no leaks, comes w new rag joint,lifetime warranty US company
RetroRanger is offline
Old July 2nd, 2013, 09:55 AM
miked's Avatar
Thanks Retro, I'll definitely look into that. I appreciate the info!
miked is offline
Old July 2nd, 2013, 10:05 AM
Each of us has his own priorities and concerns, all of which are valid, but, for the sake of comparison, I installed my junkyard JGC box over 2 years ago, and it's worked flawlessly ever since.
MDchanic is offline
Old July 2nd, 2013, 12:45 PM
That's neat.. never knew you could do that. Another thing to keep a eye out for at the boneyard...
Greg Rogers is offline
Old July 3rd, 2013, 04:39 AM
garys 68's Avatar
Over 2 years and 5000 miles on my Jeep box. Steering gear is pretty reliable, most of the 40 year old Olds boxes still work. Guessing the Jeep will last at least as long. Also, it's pretty easy to swap if it goes bad. Weighing all that, I went with the $40 used box.
garys 68 is offline
Old August 6th, 2013, 11:59 AM
miked's Avatar
OK, got a GC box (pd code) out of junkyard, no apparent leaks but pretty rusty pitman shaft. What size is the pitman nut? I can't measure close enough to tell. My 1 1/4 socket is almost big enough and 32mm is close and my Sears or Har Frgt don't stock anything larger. I've soaked it good in blaster but so far haven't been able to get the nut loose, using large crescent or monkey wrench using 3 ft of pipe for leverage. Afraid to use heat, don't want to melt the seal. I'm almost to the point of using air chisle but with my luck I will mess up the threads. It's hard to hold the box in a vise or by hand to get any force on it. Any ideas? Thanks!
miked is offline
Old August 6th, 2013, 01:00 PM
I don't recall the size - I just had something that fit in my toolbox.
I would recommend an air wrench to get this off. Also, if you mount it up on the car first, you'll have it well secured to put plenty of leverage on it.
MDchanic is offline
Old August 6th, 2013, 01:20 PM
miked's Avatar
Yep, gonna try the air if I can find the correct size socket. I'm hoping to get all the mods and cleaning done on it before I remove the one on car. Thanks Eric
miked is offline
Old August 7th, 2013, 08:46 AM
miked's Avatar
Got it! Used short pipe wrench with 3 ft cheater....now to get the p-arm off..
miked is offline
Old August 7th, 2013, 10:08 AM
RandyS's Avatar
I fought with one of those recently. Ended up going to my local O'Reilly's and rented (bought temporarily) a big Pitman Arm puller. Had to get out the big breaker bar to turn the bolt to finally break it loose............
RandyS is offline
Old August 7th, 2013, 11:32 AM
miked's Avatar
I know what you mean...the last one I did I gave up on the puller working so just turned bolt all I could then let it soak in blaster for a while then a couple of licks with a 5lb sledge and it popped off.
miked is offline
Old August 9th, 2013, 05:03 PM
oddball's Avatar
The nut is 1 5/16"
oddball is offline
Old August 9th, 2013, 08:51 PM
miked's Avatar
Hey thanks much oddball. I definitely want the right size to reinstall it and torque..I appreciate your response!
miked is offline
Old April 25th, 2015, 08:17 PM
gglow's Avatar
jeep box wrong one?
Went to put pitman arm on box only to find new box has three alignment
gaps while the arm has four. Do I have the wrong box?
This was a rebuild from Autozone. Any input welcomed.
Gerry
gglow is offline
Old April 25th, 2015, 08:24 PM
The Pitman arm shaft of the Jeep Grand Cherokee steering box has four "big splines," located evenly every 90°.
You got the wrong box, or they rebuilt that box wrong.
That's why some of us advocate going to the junkyard - at least you know what you're getting.
MDchanic is offline
Old April 25th, 2015, 09:16 PM
RandyS's Avatar
Gerry
Rock Auto sells an exact replacement, no adapters needed, and it comes with a rag joint.
RandyS is offline
Old April 25th, 2015, 11:02 PM
I saw Rock Auto had some "fast ratio" boxes and was wondering if anyone had used them. Seems like a good deal if the ratio is right.
Fun71 is offline
Old April 26th, 2015, 09:05 AM
RandyS's Avatar
Yes, that is what I ended up buying and I really like it. Plus some of them don't require a core.
RandyS is offline
Old April 26th, 2015, 02:11 PM
What ratio box did you get?
Fun71 is offline
Old April 26th, 2015, 03:26 PM
RandyS's Avatar
I got the 12:1 box and it feels about the same ratio as my DD.
RandyS is offline
Old April 26th, 2015, 03:59 PM
  #31
72 Olds CS
right here fun71
Old April 26th, 2015, 05:13 PM
  #32
The Rock Auto site shows the 974 is a 10:1 ratio:
LARES Part # 974 Power Gear; Reman One of our most popular parts
10:1 Fast Ratio; Budget (3 bolt mount; 3 - 3-1/4 turns; Includes Steering Coupling Assembly)
No big deal, I didn't know what ratio constituted "fast ratio" as I have seen 10:1 up to 16:1.
Fun71 is offline
RAMBOW
Suspension & Handling
179
March 13th, 2021 06:44 PM
RandyS
55
April 18th, 2014 01:55 PM
oldsbucket
15
June 22nd, 2013 08:47 PM
Aceshigh
June 8th, 2011 06:12 AM
MDchanic
April 30th, 2011 09:56 AM
Quick Reply: Another Jeep box question
