Replacing Leaf Springs 60 Olds
Old September 13th, 2010, 12:52 PM
misercola's Avatar
The back end of my 60 Olds is hanging a little low and I'm looking into replacement leaf springs. The local shops don't carry them. I've checked on a couple of sites that are advertised in Hemmings and they don't carry either. Can anyone recommend a reputable suspension house that would carry them. Mine, by the way, is a convertible, and requires a different suspension from the sedans -- which is part of the problem.
Thanks,
Mark
misercola is offline
Old September 13th, 2010, 01:26 PM
Have you checked Fusicks, Kanter, and Rock Auto? If not then perhaps you can have the springs repaired. I know leaf springs can be reheated and annealed again. The problem is finding a shop that still does this.
Olds64 is offline
Old September 13th, 2010, 04:49 PM
citcapp's Avatar
Find a local spring shop and have them re-arched and save yourself a ton of money. You can usually find them under truck parts/repairs in the yellow pages or do an on line search in your area. There still around Heavy truck owners use then a lot
citcapp is offline
Old September 14th, 2010, 05:27 AM
misercola's Avatar
Thanks for the suggestions. I did not realize that springs could be repaired/revitalized and used again. I will definitely inquire. One guy that I talked to said there was a way to boost the height on the car by adding something above the leafs (the equivalent of a spacer on coil springs) but he said most flatten back out again in six months.
Regards,
Mark
Old September 14th, 2010, 08:22 AM
citcapp's Avatar
Stick with rebuilding (re-arching the springs) any add-in fix will just fail in time
citcapp is offline
rmoths
October 28th, 2013 10:29 AM
dom1n1c
February 22nd, 2012 07:31 PM
TheBirds
Suspension & Handling
May 5th, 2011 09:21 PM
misercola
September 5th, 2010 05:10 PM
Fletch
January 20th, 2010 02:10 PM
Quick Reply: Replacing Leaf Springs 60 Olds
