| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Super Moderator
My setup
A lot of people have asked me for details of my suspension. I have always been a street strip straight line guy so about 2 years ago I started researching A-body suspension.
I don't deserve any credit for what I did. I just coppied what has worked for others. Lots of guys on Chevelles.com are using the same setup and having good results. The hardest part was getting what I wanted and not going overkill. Just like bigger is not always better for cam shafts and carburators it also applies to suspension parts , springs, and sway bars. In my mind I wanted a car that drives like a modern sports sedan. I'm not going to run the cones every weekend but if I have to dodge a ladder in the middle of the highway I wanted to do so without scaping the door handles on the pavment. The best thing I did was make a call to Marcus at SC&C based on many many recomendations. http://www.scandc.com/faqs.htm I told him what I wanted out of my car. He told me what I needed on several occasions even down selling me or telling me to buy something someone else carried because it would fit my needs better even though he carried a competing product. I followed all his suggestions and ended up with a car that is even more than my expectations. springs- Eibach front was perfect for the low height I wanted but had to cut about 1/2 coil in back and will probably cut another 1/4 coil for perfection shocks- Bilstein hot rod shocks sold by OPG same as thier other shocks but painted black with black boots instead oof yellow with blue boots front upper control arms and ball joints- stage II + kit consists of Howe tall ball joints and SPC fully adjustable upper control arms steering box - Lee custom 12.7:1 bluprinted box 670 series (drives like a rack) front bar- stock bar from a 66 GTO with rubber bushings and urethane end links rear bar- OPG 1" aftermarket bar rear control arms- Currietrac upper and lower arms with johnny joints. Allows full articulation with no binding rear axle bushings- stock replacement rubber
__________________
-Richard 66 Cutlass ragtop my way ![]() Keep watching your cotton candy coated TV while your world falls apart around you... |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Did you also replace the rest of the front suspension like the tie rods and tie rod ends center steering arm or whatever that thing is called? I want to do something very similar to your setup without going overboard, but I also want to make sure the rest of the parts get replaced as well since I'm going to have it all apart.
Last edited by BerBer5985; June 25th, 2009 at 05:44 PM.. Reason: Needed to add something |
#3 (permalink) |
Oh, and I'm sorry but one more question for you....I want to do disc brake upgrades on all 4 corners and maybe try the 2" drop spindles with the package they offer. Would that be a good route to go for lowering the vehicle, or would getting stock spindles and then lowering springs be the best route or a combination of both?
#4 (permalink) | |
Super Moderator
Quote:
__________________
#5 (permalink) |
Seasoned beater pilot.
Hey Richard, any 60' times with the new setup yet? I'm curious how she sticks.
__________________
#6 (permalink) |
I'm going to stick with stock 15"x8" all around. So I guess just the normal size brakes.
#7 (permalink) |
Super Moderator
Thanks Richard
Very good information
__________________
69 H/O 69 442 convertible 69 Vista Cruiser 69 442 hardtop "Growing old is mandatory,Growing up is optional" |
#8 (permalink) |
is Fast Enough ...
I have '70 442 w/ disc brakes...
Do I run my spindle with the tall ball joints ..? |
#9 (permalink) |
Super Moderator
Disk brake spindles are fine but I an not sure if 15" wheels will work or not. I would put a call in to Mark. He is sometimes hard to get ahold of but persistance is well worth it. Set aside at least 30 min to talk to him though. There are no short conversiontions with him.
__________________
#10 (permalink) | |
Super Moderator
Quote:
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| This will be my olds 350 setup | 1973oldsomega | Small Blocks | 55 | July 28th, 2009 11:33 AM |
| heater setup | eight_bit_micro | General Questions | 8 | March 10th, 2009 08:28 PM |
| Stick-shift setup for a 65/70 B-body | Kennybill | Parts Wanted | 2 | May 10th, 2007 01:52 PM |
| Olds Serpentine Setup | snowri | Big Blocks | 1 | March 29th, 2006 05:36 AM |
| 1974 z-bar setup | anthonysteve38 | Transmission | 2 | December 11th, 2004 12:47 PM |
