Swapping 1950 98 & 88 steering boxes.
Old June 18th, 2016, 04:44 AM
Erik Andersen's Avatar
Location: Cairns, Australia and Port Moresby, Papua New Guinea
I am looking at the steering of my 1950 88, which has worm and roller steering and thinking the recirculating ball box apparently in 98s from the same year might give a lighter feel, and r.b. Has a reputation for longevity.
Has anyone tried, heard of, or have any thoughts on that swap?
Cheers
Erik
Erik Andersen is offline
Old June 18th, 2016, 09:12 AM
coldwar's Avatar
As your 1950 88 is a Fisher Body car build, and the 1950 98 is a Fleetwood Body car build, you have to be careful about interchange of parts. Many parts are common, but there are also differences. 1949, 50 and 51 98 are FW body, 1949, 50 88 and 51 88A and B are Fisher body builds.
The power steering from 1952 88 and 98 which in 1952 are all Fisher will directly swap to your '50. These are not like later GM cars, the box and steering shaft are one piece with no rag joint coupling. The 1952 assembly is just about the same layout as your '50, with detail differences. 1953 has a shorter overall length meaning the steering wheel is closer to dash but can also work, and helps if the driver is not skipping any lunches. Finding mounting room for both steering pump and generator is a challenge but can get done.
I sort of missed that the 1950 88 box is worm and sector, I thought they were all recirculating ball. The power steering parts I mention are at a premium in 2016 as those who appreciate these cars grow older, including myself. I have enough PS assemblies for the cars I drive, just barely. You might nose around to find the parts if needed. The needed steering effort even when the cars were new was the reason power assist was developed. It's a fabulous working system.
coldwar is offline
Old June 18th, 2016, 10:11 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I think it is interesting they did not use whitewall tires on the car in the commercial. Would have looked much dressier at the time.
redoldsman is offline
Old June 21st, 2016, 05:23 AM
That commercial is very cool!
Olds64 is offline
Old June 21st, 2016, 05:04 PM
Thanks guys, unfortunately the rallies the 88 is destined for don't allow upgrading to power steering, so I thought that if the 98 has a less frictioned system that was still reliable it would be a period-correct swap which would make the steering a bit lighter.
I'm also keen to replace the steering column with a collapsible one to mate to the steering box - I'm not looking for tilt or any of the fanciness; just something that's less likely to spear me!
Cheers
Erik
Old April 28th, 2022, 07:23 PM
Hi there. Back in 2016 you very kindly set out some thoughts about replacing the manual steering box of my '50 Olds with an Olds power steering setup from a few years later. I didn't want to go that way at the time, but as of a few days ago I have purchased a (probably) '53 Olds P/S for installation and your words from 6 years ago have been very helpful - even after all this time.
Thanks for writing it back then.
Cheers
Erik
Old April 29th, 2022, 04:24 AM
Erik, I'm glad coldwar's advice helped you. Now post pics of your Olds with the new PS setup stat!
Olds64 is offline
orange442
January 23rd, 2016 09:50 PM
orange442
July 8th, 2015 10:54 PM
anthonyP
November 20th, 2014 09:50 AM
orange442
October 30th, 2014 04:03 PM
69442murph
June 10th, 2014 07:36 PM
Quick Reply: Swapping 1950 98 & 88 steering boxes.
