Head Gasket question for a 1936 HK Huber Tractor
Old July 31st, 2015, 07:35 PM
jensenracing77's Avatar
I am working on a 1936 Huber tractor. It ran 5 years ago but 3 years ago we found it had a stuck cylinder. We filled that cylinder with ATF and never looked at it agin till today. I got it to my house and want to take the head off. Head gaskets are not available anywhere I can find. My grandfather said last time he had it off he had to reuse the head gasket. Is copper spray going to be good enough to reseal a gasket? I hope it is a copper head gasket. If it is what do I do to reseal a copper head gasket? The max RPM is 1150 but I have no idea wat kind of pressure this engine has.
jensenracing77 is offline
Old July 31st, 2015, 07:53 PM
Phantom Phixer
Charlie Jones's Avatar
Look around the engine for a data plate.
The engine is probably from an industrial engine manufacturer, (LeRoi, Continental , Waukesha, Buda, etc.)
Knowing that and the engine model may make the search much easier.
Charlie Jones is offline
Old July 31st, 2015, 08:11 PM
That's a cool tractor.
oldcutlass is offline
Old July 31st, 2015, 09:57 PM
costpenn's Avatar
Eric, see if one from a Hoyt Clagwell might work.
costpenn is offline
Old August 1st, 2015, 04:02 AM
kitfoxdave's Avatar
If it is flat copper sheet, you might be able to have one cut on a cnc plasma cutter using the old one as a pattern.
kitfoxdave is offline
Old August 1st, 2015, 07:23 AM
Octania's Avatar
If so, make a few and corner the market!
re-using by means of cleaning and applying copper spray is another alternative for low compression industrial engines.
Or, have Lisa Douglas cut out some hotscakes with the cookie cutter and use the remaining rectangle with holes as a gasket.
Octania is offline
Old August 1st, 2015, 06:02 PM
There is no way I can reuse this head gasket. I am told there is none available. Now what? I joined a vintage tractor forum. Maybe they will have something?
Old August 1st, 2015, 07:19 PM
Phantom Phixer
After doing a little Goggle research , I believe you may have a Waukesha CHK engine .
http://www.farmcollector.com/company....aspx?PageId=2
Check the bore and stroke if the head is off , it should measure 5 & 1/8 by 6 & 1/4.
Here are a couple of sources :
Gerald Lettieri
132 Old Main St.
Rocky Hill, CT 06067
203-529-7177
He deals in obsolete gaskets for antique cars and other vehicles.
Molina Gaskets
23126 Mariposa Ave.
Torrance, CA 90502
213-539-1883
They custom make copper and asbestos head gaskets.
Hope this helps.
Old August 1st, 2015, 07:52 PM
Phantom Phixer
http://www.yesterdaystractors.com/cg...=orphans&th=80
Old August 2nd, 2015, 06:25 AM
Lansing built
1970cs's Avatar
Eric, what model Waukesha engine? I was thinking Howards or Toms agri diesel.
Pat
1970cs is offline
Old August 2nd, 2015, 07:01 AM
Pat
Here is the engine tag and tag on the rear fender. The engine tag is stamped CHK4C 5 1/8 X 6 1/4 361817 3-1935
Old August 2nd, 2015, 08:35 AM
Lansing built
1970cs's Avatar
Your correct! Your going to do a custom job. Here is just one of many that do this! I don't have any experience with these guys.
http://www.coppergaskets.us/
Charlie has you headed in the right direction.
Pat
1970cs is offline
Old August 2nd, 2015, 03:14 PM
I got the piston out today. The rings will be fine to reuse. Going to take lots of cleaning. I had to take the screen off the oil pump and clean it and the oil filter center tube was almost rusted shut. I think I have found all the trouble areas. Now just to clean it all up and put it back together. My uncle is looking but he thinks my Grandfather has picked up a new head gasket for it in the past couple years. I am trying to fix this without my grandfather finding out. He just broke his hip a couple weeks ago and will be back home in the next two weeks. He has mowed my grass for the past three years while I was dealing Oldsmobiles and restoring my W-30. Now that the car is done I wanted to get this done to repay him.
Old August 2nd, 2015, 05:22 PM
Lansing built
1970cs's Avatar
The last Waukesha I worked on was about 18 years on a 1855 Oliver that had head gasket issues.
I am more of Ford, Allis Chalmers, Shibura, Deutz and Kubota diesel expert. Along with small engines Briggs, Tecumseh and Honda.
Pat
1970cs is offline
Old August 2nd, 2015, 07:46 PM
Octania's Avatar
Well, the original head gasket was made by someone
Therefore someone can make another or a suitable substutute.
just gotta find that someone.
Octania is offline
Old August 3rd, 2015, 09:48 AM
I found one in stock at http://www.olsonsgaskets.com/ $157.60 for the head gasket but I will have it this week.
Old August 3rd, 2015, 07:16 PM
Lansing built
1970cs's Avatar
Great Eric! Make sure that you still use the copper coat on it. Hopefully that will have the Torque specs. also.
Pat
1970cs is offline
Old August 3rd, 2015, 08:29 PM
Phantom Phixer
Wow! That beast has 516 cubic inches and only four cylinders .
Old August 11th, 2015, 06:04 PM
First attempt at starting it up. Didn't go so well.
http://s654.photobucket.com/user/jen...95419275709408
Old August 11th, 2015, 06:09 PM
I ended up having to pull the plugs and squirt a very small amount of gas into the cylinders and it fired up. I did not get the first start on video but here is the second time starting it.
[object Url]
Old August 11th, 2015, 06:17 PM
Lansing built
1970cs's Avatar
Excellent job Eric! I was watching the video and was cringing when you had two hands on the crank handle, closed hands. I hope that bugger does not kick back on you.
Pat
1970cs is offline
Old August 11th, 2015, 06:49 PM
I did not have them locked together. When it kicks back it just blows right through your hands. You just have to be sure your leg is not in the path of the crank. It takes so much to crank you have to grip it very hard. Have to always pull up and never down or it would take your head off.
ihengineer76
May 10th, 2013 10:01 AM
jensenracing77
July 30th, 2012 11:13 PM
1969cutlazz
May 16th, 2010 08:07 PM
coldwar
March 15th, 2010 06:22 PM
Sixoh
August 8th, 2006 05:11 AM
Quick Reply: Head Gasket question for a 1936 HK Huber Tractor
