1972 442 W30 with Air Conditioning?
Old February 17th, 2013, 02:36 PM
DocOlds's Avatar
I have a 1972 442 W30 with air conditioning. I've had the car for many years and never thought much about it, but I've read in a few places that no W30's ever came with air conditioning. Is this true? Is it possible that because the 442 was an option in 1972 and not a model, that someone could have ordered it? It sure looks all original to me, please. What are your thoughts?
DocOlds is offline
Old February 17th, 2013, 02:48 PM
"Car"mudgeon
GAOldsman's Avatar
A/C wasn't available in '72 with W30
Last edited by GAOldsman; February 17th, 2013 at 03:00 PM. Reason: Corrected wrong info
GAOldsman is offline
Old February 17th, 2013, 02:54 PM
jensenracing77's Avatar
?? are you sure that is right? I did not think any 72 W-30 could have A/C?
jensenracing77 is offline
Old February 17th, 2013, 02:59 PM
"Car"mudgeon
GAOldsman's Avatar
You are right I read wrong.... again sorry no A/C available with W30 in '72. If it is a '72 W30 it would have an X in the VIN
Old February 17th, 2013, 03:01 PM
oldsmobiledave's Avatar
No a/c
Originally Posted by GAOldsman
A/C was available in '72 with automatic transmission.
No.....it was not. No a/c on W-30 in 1972. The standard axle ratio was 3.42 with 3.73 optional and neither ratio could be had with a/c.
oldsmobiledave is offline
Old February 17th, 2013, 03:04 PM
Fyi
Is this an X code car? If it is then someone added the a/c.
Old February 17th, 2013, 03:07 PM
On the other side of the coin, if it's the W29 package the Cutlass, Cutlass S or Cutlass Supreme vert could all be ordered with AC and 'look' like a 442. Anyone could have re-badged the car to make it look like the W30. As others have pointed out, the X engine code will verify if it was a W30 or not. Also verify that it was built at Lansing - that's the only factory that produced W30's.
Allan R is offline
Old February 17th, 2013, 03:12 PM
DocOlds's Avatar
Yes it's an X in the VIN and it's a true W30. It's just that everything on this car seems all original. I c an't find any evidence of anything looking new or replaced. The car was filthy when I bought it and had been sitting for many years. I always thought in 72, Olds dealerships could have ordered non-standard options since they knew the 442 had become an option package. It has a 3:42 posy and all of the numbers are matching. Hmm, I'm scratching my head...
DocOlds is offline
Old February 17th, 2013, 03:22 PM
"Car"mudgeon
GAOldsman's Avatar
Probably a dealer add on
Old February 17th, 2013, 04:32 PM
DocOlds's Avatar
ok so for the ultimate question then. If it was possible it was a dealer addon, is keeping it installed going to depreciate the value or should I remove it so as not to provoke any questions? I've never seen another real 73 w30 with AC. In fact I don't think I've ever seen any 70 or 71 W30s with it either. What do you suggest?
DocOlds is offline
Old February 17th, 2013, 05:12 PM
Diego's Avatar
Plenty of '70 W-30s had AC.
Diego is offline
Old February 17th, 2013, 05:15 PM
If it was dealer installed you will see where they had to modify the firewall to make it work.
Old February 17th, 2013, 05:35 PM
Specifically, the pass-through slot for A/C was vertical (the place where the evaporator box seals to the firewall), while the slot for the heat-only was horizontal.
You would just barely see a bit of the open part of the horizontal slot that would have to be patched, just past the inside edge of the evaporator box.
Every other part of the heat-only system, if I recall, can be completely and seamlessly replaced by an A?C system, so, if done well, there should be no other evidence.
MDchanic is offline
Old February 18th, 2013, 03:52 PM
The 3.42 gears were standard for the 72 W30 cars; the option was 3.73 gears. Posi (limited slip in Olds terminology) was also standard - G80 included in the W30 performance package.
Allan R is offline
Old February 19th, 2013, 08:13 AM
stevengerard's Avatar
I know of a few 70 W30s with automatics and AC that have 3.42s in them, including mine but I can't prove mine is original, but a few others have.
I'd leave the AC in before I'd take it out.
stevengerard is offline
Old February 21st, 2013, 02:25 PM
where r you?
What is your location?.....if this car sold new in Canada you can get GM of Canada documentation on the car that will tell us if it has W-30 & C60 options.
Fill out your profile & include location.
Jonb442
October 4th, 2014 08:23 AM
Timmy1966_442
September 30th, 2013 10:58 AM
rand5204
April 10th, 2012 06:37 AM
12nvrich
January 5th, 2012 09:51 AM
RPD1659
May 21st, 2008 07:03 PM
Quick Reply: 1972 442 W30 with Air Conditioning?
