ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Chassis, Drivetrain, Brakes, & Related > Chassis/Body/Frame
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old October 11th, 2008, 10:30 PM   #1 (permalink)
The_Jeremiah
Solid Motor Mounts
Where can you get em? Looking to put em in my 69 Cutlass with the 350/TH350
__________________
69' Cutlass 4 door. Built 455 inside, grandma's grocery getter outside. Best sleeper in disguise.
The_Jeremiah is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old October 12th, 2008, 06:38 AM   #2 (permalink)
74 Omega
74 Omega's Avatar
Quote:
I believe I have seen them in the SUMMIT and/or JEGS books.
__________________
Dave
1974 Olds Omega S (Who Cares about MPG)
1999 HD Road King Classic (50 MPG)
2001 Monte Carlo SS (25 MPG)
2004 Silverado 2500HD 4x4 Crew Cab (10.5 MPG)
2001 Oldsmobile Intrigue
www.sdcookman.com
74 Omega is offline   Reply With Quote
Old October 12th, 2008, 07:29 AM   #3 (permalink)
joe_padavano
Super Moderator
Quote:
Not for an Olds motor you haven't. You can buy solid mounts for an Olds motor from the usual Olds specialists (and expect to pay accordingly), but I have to ask, why do you want them? Unless you are making incredible amounts of HP and torque, or you are bracket racing and need every bit of consistency, the solid mounts are not necessary. All modern replacement rubber motor mounts have the interlocking feature that prevents engine movement even if the rubber fails (as I just found out on my Custom Cruiser). If you don't trust this, run a torque limiter strap on the driver's side.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is online now   Reply With Quote
Old October 12th, 2008, 09:41 AM   #4 (permalink)
Run to Rund
I make my own for my 66 out of 1/4" thick plate. I use a chunk of stock frame with pieces welded to it to make sure they are aligned right. It takes a while to cut and fit, then weld the pieces. So, if you are going to custom make mounts for your car, it is a lot of work and they have to fit right. If one of the Olds specialty vendors offers them, it is worth it for a single set or so. You might check on Realoldspower.com forum.
Run to Rund is offline   Reply With Quote
Old October 12th, 2008, 09:52 AM   #5 (permalink)
J-(Chicago)
Seasoned beater pilot.
J-(Chicago)'s Avatar
Just bolt a chain from the frame to the driver's side of the motor.
Folks, The Jeremiah is young, and learning as he goes.
Any 350 you build probably won't even need the chain/torque strap/ or solid mount. You could probably be running in the 12s in the 1/4 mile and not even need one yet.
You can order a front motor plate that ties everything into your frame and run an electric water pump, but honestly you will probably never need it. http://www.rocketracingperformance.c...otor_plate.htm
__________________
I'd rather have a numbers matching poker hand.
J-(Chicago) is offline   Reply With Quote
Old October 12th, 2008, 10:59 AM   #6 (permalink)
yammiman
yammiman's Avatar
I bought mine from Dick Miller a few years back - not sure if he has them, but you could call
http://www.dickmillerracing.com/cgi-...1ac+1225735394
yammiman is offline   Reply With Quote
Old October 12th, 2008, 12:30 PM   #7 (permalink)
The_Jeremiah
Quote:
Lol thankyou for that J. Yes i am young and learning... but im doing a lot of these little things to my oldsmobile to make it ride how i want it to... i have always been a fan of a really harsh ride, and i know from riding in other muscle cars with solid motor mounts, that they help out a lot lol! I finally have my oldsmobile up and running, its not pretty... but it sounds and runs perfect! ill have to get some pictures for you guys, and i cant remember if i mentioned or not, but im going to school, and working so i dont have any free time!!! but im trying to get on here as often as i can.
__________________
Old October 12th, 2008, 12:35 PM   #8 (permalink)
The_Jeremiah
oh, and yes i will be bracket racing with it when the time comes
__________________
Old October 12th, 2008, 04:34 PM   #9 (permalink)
yammiman
yammiman's Avatar
Conventional mounts do act as shock absorbers between the frame and engine - caution should be taken if you plan on doing alot of street driving - I have seen cracked blocks with street driven cars with solid mounts
Old October 14th, 2008, 10:01 AM   #10 (permalink)
The_Jeremiah
ok, ill take note of that. DM has em still, do you know if you need to grab a solid tranny mount to? thanks
__________________
Old October 14th, 2008, 10:08 AM   #11 (permalink)
yammiman
yammiman's Avatar
I'm just using a conventional tranny mount
Old October 14th, 2008, 08:05 PM   #12 (permalink)
The_Jeremiah
ok cool. Well thanks guys, glad you could help me find em. I just love the rough ride, and i guess it might help in the bracket racing... lol if its too rough, they will end up for sale here for probably half off anyway...
__________________
Old October 15th, 2008, 08:09 AM   #13 (permalink)
Run to Rund
DO NOT use a solid tranny mount with the solid engine mounts.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Body mounts kevdog442 Chassis/Body/Frame 1 July 22nd, 2008 03:31 PM
body mounts 65 starfire Chassis/Body/Frame 0 February 7th, 2008 12:24 PM
Body mounts phantom.10 Big Blocks 2 August 26th, 2007 04:48 AM
64 jetstar 88 mounts jetsled Eighty-Eight 2 March 9th, 2007 06:40 AM
Body mounts stuart Chassis/Body/Frame 0 August 17th, 2004 09:18 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
