mounting into a rotisserie
Old November 2nd, 2011, 04:57 PM
CLcutlass's Avatar
anyone have any pics of how to mount a car into a rotisserie without using a post lift....I purchased a home made rotisserie that was used on a charger but the body has to lift way up there to mount.
CLcutlass is offline
Old November 2nd, 2011, 07:55 PM
W70442's Avatar
I think each car mounts to the rotisseri using brackets made specifically for attaching that car to the given rotisseri. You may be able to modify the "charger" brackets to attach your car but there will likely need to be some welding done to make the brackets you need for mounting your car.
Hopefully, someone will follow with pics for you but I think that's what will be needed.
W70442 is offline
dads72
April 17th, 2014 02:18 PM
Okie Rocket
August 15th, 2013 06:01 PM
outlawspeeder
April 23rd, 2013 03:34 PM
macrover
September 13th, 2011 11:41 AM
BigBertha442
February 24th, 2008 12:44 PM
Quick Reply: mounting into a rotisserie
