| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Senior Member
question on interchangeability
would and front and rear sway bar from a 68 GTO fit on a 70 cutlass? the guy has front and rear the diamater is 1.5 inches not sure if thats stock or after market
but would the GTO sway bars bolt up?
__________________
![]() my cutlass as of 08/27/2007 |
#2 (permalink) |
Yes they fit and yes they're aftermarket if they are 1 1/2". I think only Herb Adams sold the 1 1/2" front and back bars. You will need the larger frame brackets and isolators for the front bar and you will definitely need boxed rear arms. These will make a tremendous difference in handling. Herb Adams used to sell special threaded inserts that swaged into the frame for attaching the front bar since the stock self-tapping bolts tended to pull out with this much stiffer bar.
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
| Thread Tools | |
| Display Modes | |
