Front upper control arms
I believe the 1964 was the only year F85/Cutlass put grease zerks here. Have you tried removing and cleaned the zerks or putting new ones in? John
What frequently happens is that the old grease gets hard and won't flow out of the way when you try to put new grease in. I've had some success with backing out the grease fitting and spraying solvent (carb cleaner) in the hole, then working the suspension to loosen the old grease. Of course, once it's loose, you need to flush that solvent mess out with fresh grease. These "bushings" are the metal-on-metal screw thread type, so the solvent won't hurt anything.
DR_DAN
March 9th, 2015 05:48 PM
197064buickspec
September 9th, 2013 09:17 PM
1971viking
November 1st, 2012 07:20 PM
