How can I tell if it's a real 442?
I ran the vin on http://v8cars.hu/oldsvin/decode.php and it shows
Year: 1972
Division: Oldsmobile
Series: Cutlass S
Body: Holiday Hardtop (2 door)
Engine: 455 (7.5) V8 4BBL
Here is a link to the car.
http://cars.oodle.com/detail/1972-ol...-www-_-NA-_-NA
Thanks,
Jim
Year: 1972
Series: Cutlass S
Thanks,
Jim
That's one of those "can't be disproven" cars
So, much like the other thread yesterday-
If it has all the right stuff
and none of the wrong attributes
and you say it is a 442, or W30, then it is.
Whether the boys in Lansing made it in 1971-2 or someone else did, later, is immaterial and perhaps unproveable.
Though it cannot be verified as a factory '72 442 without documentation, it is still a factory U-code 455 automatic. The next desirable 455 would be the V-code 4-speed model. A '72 W-30 as we know had it's "documentation" in the VIN, with the X engine code, though there was no distinction between automatic and 4-speed models.
In Ohio,there was a factory 72 Cutlass 'S' with the U-code 455. It was later "converted" to a 442. It's hard to say that it was originally a Cutlass,but it was.
If it is a U-code,that's pretty good,and a good chance that it is a 442. The ones with the K-code,M-code,and whatever else,are a crapshoot without paperwork.
The X-code is a given.
The really rare of the rare. The elusive '72 Hurst/Olds with the W-30 engine.
I've only seen one, it was on eBay with a factory sunroof, which was probably a good idea since A/C was not available with W-30 option.
Unfortunately, it was very, very, rotted. Does anyone know how many W-30 optioned Hurst/Olds were produced, and how many with the sunroof option?
Yeah, but in this case, thinking you are getting a W-30 and actually ending up with an L77 H/O probably wouldn't disappoint you.
I've not seen such a car, but according to some original ordering literature the "H" code could have been ordered in conjunction with the W-29 "442 Appearance and Handling Package". The option lists what is included and states "available with any engine". Years ago, I was interested in such a car that was "supposedly" a customer factory order and was "documented" to prove the authenticity. The car was a 2dr hardtop, Red w/ White vinyl top and white buckets and console. It was out of state, but I never went to see the car in person. I'm curious on this topic myself. If anyone here has a documented "H" code W-29, I'd like to know about it. It is somewhat surprising to me that here aren't more real '72 442s out there---the group of items included in the W-29 option was WELL WORTH the few dollars it cost.
Only two (2) 72 H/O s with the W30 option and sun roof were built by Hurst. There may be some clones, however production info I saw on micro-fisch said two.
BTW: Jim Gedhy in Austin, Texas has one!
I'm with Dave. Why do you say this? While not a desirable combo, I've never seen any factory documentation that proves that the H code engine was not available with RPO W29.
H Code
I stand corrected, after further review the play on the field stands I am wrong. I checked the 72 assembly manual and salesmen's spec and you guys are absolutely corect. I don't why I thought the base engine was unavailable with a W-29 option but it clearly says ALL ENGINES.
sx455raidercelticfan
December 5th, 2010 06:55 AM
