Want to convert to rear discs, but what is the axle pattern?
Old January 9th, 2015, 05:21 PM
Oldsragger's Avatar
Hello, im woundering what bolt pattern i have for the brake install, does any know what my 10bolt 8,5" non c-clip axle have? i think i have that one with red circle around...
and i found this kit on ebay, but it says its for A-body cars, but for non- clip axle,, so could it fit my axle too? did the a-body axle have same drum setup like an b-body axle with 9" drums and 5x4,75" pattern?
http://www.ebay.com/itm/Rear-Disc-Br...45538a&vxp=mtr
Or maybe this? for f and x bodys
http://www.ebay.com/itm/Staggered-GM...3994f2&vxp=mtr
thanks
Oldsragger is offline
Old January 10th, 2015, 10:54 AM
The Olds/Pontiac pattern circled in blue is the 1959-64 axle. You have the GM/Chevy axle pattern.
joe_padavano is offline
Old January 11th, 2015, 10:12 AM
Oldsragger's Avatar
Ok thanks, then im sure on it.
Old January 11th, 2015, 11:25 AM
dc2x4drvr's Avatar
Which kit are you using for the rear disc conversion?
dc2x4drvr is offline
Old January 12th, 2015, 01:14 PM
Oldsragger's Avatar
Im talking with a wilwood dealer on ebay now, i have sent him pictures of my axle and bolt patterns so maybe he can help me with a kit. i will tell you more when i know more
Old January 13th, 2015, 08:00 AM
Oldsragger's Avatar
Hi again, can someone help me with this, What is the thickness of the backing plate? And what is the distance from the outside of the backing plate to the outside of the axle flange, when the axle is pushed all the way?
look at the pic below, the blue one is what i need to know, the other pic is my axle, somebody knows the dim on the axle with the bolt pattern?
Its hard for me to find out right now cause i cant dissaseble the brakedrume and check it self :/
Old January 18th, 2015, 04:31 AM
Oldsragger's Avatar
Nobody knows? (look question above)
thanks
Old January 25th, 2015, 07:46 PM
jordan845's Avatar
i'm doing one now I got my setup off an 85 Camaro
jordan845 is offline
Old January 26th, 2015, 01:04 AM
Oldsragger's Avatar
really, does it fit? is it for 15" rims and up? and have u a Non c-clip axle 10 bolt 8,5" that the 85 camaro kit fits on? and bearingsize out dim 65mm? the seller need to know the axle flange distance if so in my opinion.. and the disk dim for the bolt pattern.
or do u have a link for ur kit? any tip would help ,im not sure what axles the camaro 85 has
Old January 26th, 2015, 05:28 AM
jordan845's Avatar
look on e bay for proportioning valve and backer plates the rest you can get at rock auto. You will have to get the axle hub turn down for the disc to side on.
rmsikorski66
April 26th, 2014 06:38 PM
txrob779
Drivetrain/Differentials
15
February 26th, 2014 11:08 AM
lshlsh2
February 3rd, 2013 08:40 AM
Aceshigh
Brakes/Hydraulic Systems
June 24th, 2010 09:05 AM
71 delta88guy
April 6th, 2009 08:24 PM
Quick Reply: Want to convert to rear discs, but what is the axle pattern?
