No fluid to wheel cylinder?
I'm bleeding the brakes after replacing all wheel cylinders and the master cylinder. I bench bled the master cylinder, and got fluid through to three wheels no problems.
But the left front isn't getting anything. Any suggestions on common problem areas or where I should check?
I should add that the car has been in storage for years, and had nothing in the way of working brakes when I got it.
sometimes the pushrod length is different also between mastercylinders. a prob ive been noticing on a few posts. and if its getting to one front wheel, the other is in the same line as well, so it also should be getting pressure
Would that hold true with a new wheel cylinder, or is it more applicable to old ones? (I'll give it a shot anyhow)
I used a vacuum bleeder at each wheel, so the pushrod length shouldn't be entering into the equation. The bleeder didn't suck any fluid down, although the vacuum dropped real slowly - like there's a blockage in the line. (Still have to check the rubber line) Pumping the pedal didn't force anything through either.
Sounds like there may be an obstruction
in the line then. You may try pulling the line
off, then have someone push the brake pedal
down slowly and push the crap out of the line.
While the pedal is still down, put your thumb
over the end, then they can let up, and then push down
again. This way you push the crap out without sucking
air back inside the line. It will be somewhat messy.
Suggest goggles, don't get that stuff in your eyes.
It sounds as though you've just been using a vacuum bleeder.
Have you had someone push the pedal yet?
I'd give that a try - have a helper pump up the pedal and then push it down as you open the bleeder.
I was able to bleed that wheel using the pedal pumping method. Test drive tomorrow. Thanks for all the suggestions!
rcdynamic88
Brakes/Hydraulic Systems
August 14th, 2014 06:00 PM
1k442
November 30th, 2009 12:37 PM
cfair
June 8th, 2009 12:37 AM
