| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
72 cutlass front drum to disc conversion
I have a 72 cutlass supreme and I am wondering if it is possible to use front disc brakes set up from a 73 or newer cutlass or any other gm car to replace the drums on my 72 ?
__________________
-72 Cutlass Supreme -02 Olds Intrigue -05 GMC SIerra 4X$ Crew Cab -85 Dodge Ram 1/2 Ton |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
The only 1973 or 74 car with compatible front discs that I can think of off the top of my head would be the Nova. you are limited to 68-72 A bodies (to include the grand Prix and Monte Carlo), the Nova up to 1974.....and I think there may be one or two others. if you find one of those cars, remember to take the proportioning valve and its bracket, the booster, and the front hose brackets.
Additionally, you CAN convert your exsisting drum spindles to discs by machining the third hole to mount the caliper bracket (purchased aftermarket) and then you can buy everything else including an aftermarket proportioning valve. John |
#3 (permalink) | |
Super Moderator
Quote:
http://classicoldsmobile.com/forums/...sk-brakes.html
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#4 (permalink) |
Do you know if a 1973 olds omega will fit?
__________________
#5 (permalink) |
Super Moderator
The Omega is an X-body. From above:
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 72 Cutlass Disc Conversion | jtsautos | Brakes/Hydraulic Systems | 4 | October 7th, 2009 02:28 PM |
| 66 Toronado Front Drum to Disc Conversion | elcaminodave | Brakes/Hydraulic Systems | 4 | August 9th, 2009 05:57 PM |
| Low cost front disc brake conversion | OLD SKL 69 | Brakes/Hydraulic Systems | 7 | March 1st, 2009 05:59 PM |
| question for front disc conversion? | olds1968 | Brakes/Hydraulic Systems | 12 | February 18th, 2008 08:58 PM |
| Drum to Disc Conversion on 78 Cutlass | crazyiball | Cutlass | 8 | January 18th, 2007 07:40 PM |
