Brake booster/dual master cylinder
For a 65 starfire is it possible to run an aftermarket dual master on the original brake booster or is there an aftermarket bracke booster I need to buy to run a dual master?
Thanks in advance, Zach
The dual master cylinder requires a shorter pushrod from the booster to the M/C. Inline tube sells these, but you have to disassemble the booster to change it. Alternately, get the booster for a 1967 full size, which came with a dual M/C. This will bolt into your 65.
w31man
January 7th, 2013 04:31 PM
virtualwsp
Brakes/Hydraulic Systems
June 13th, 2012 02:00 PM
rwtrader
January 11th, 2012 09:33 AM
66-3X2 442
September 22nd, 2011 07:53 PM
eddieunderground
November 26th, 2010 09:46 PM
