HARD pedal
Old September 12th, 2016, 05:17 PM
Aqua67's Avatar
HARD pedal
Having a problem with brakes on my 67 delta custom. Pedal is very hard and feels as if i dont' even have power brakes. Car is hard to stop unless i really lay on the pedal. Brake booster is new as is the master cylinder. Brakes on all 4's are good and rears have new springs on the self adjusters. Anybody know what the vacuum should be? I can pull the hose out of the booster and not get much of a whoosh.
Aqua67 is offline
Old September 12th, 2016, 06:15 PM
The hard pedal really sounds like a booster issue. New booster does not necessarily mean a properly working booster.
Fun71 is offline
Old September 12th, 2016, 06:25 PM
Tedd Thompson's Avatar
Are you sure all 4 wheels are stopping?Could the rears be the only wheels that are working?
You might try to slide to a stop on gravel and see if all four wheels are trying to lock up. but as mentioned above it very well could be a bad new booster.... Tedd
Tedd Thompson is offline
Old September 12th, 2016, 06:34 PM
Originally Posted by Aqua67
425 rough idle
I'm having issue with really rough idle on my 67 olds, 425 4bbl. When it's cold it runs perfect, and no problem driving and cruising along after it's warmed up but when i come to light or idle for any reason it idles very rought as if it were bout to stall.
HARD pedal
Methinks there may be a relation between these two threads, no?
MDchanic is offline
Old September 12th, 2016, 07:35 PM
Aqua67's Avatar
[QUOTE=MDchanic;953002]Methinks there may be a relation between these two threads, no?
- Eric[/QUOTE
Other than the obvious (they're both mine). Is this a riddle??
Are you thinking vacuum leak may be the relation between the 2???
Aqua67 is offline
Old September 12th, 2016, 07:39 PM
Yes.
MDchanic is offline
Old September 12th, 2016, 07:42 PM
same but different
don71's Avatar
None or low vacuum means poor power assist=hard pedal.
don71 is offline
Old September 13th, 2016, 07:31 AM
There is a quick-and-dirty test. Simply disconnect the vacuum hose from the booster and plug it. Obviously you will no longer have power brakes, so be careful. If the engine runs better now, you have a leak in the booster - replace it. If the engine runs the same, fix that problem, as the low vacuum is causing the booster issue.
joe_padavano is offline
68oldscutlass
Brakes/Hydraulic Systems
August 9th, 2012 07:27 AM
RogerC
April 14th, 2011 04:36 AM
iuhoops83
October 7th, 2009 09:30 AM
KQQLCAT
April 29th, 2009 05:51 AM
tarps3
June 29th, 2008 05:00 AM
Quick Reply: HARD pedal
